Squeaking, cricket like noise
Old Jun 21, 2004, 05:22 PM
Mistasparkle's Avatar
Hey guys.
My car has developed a wierd noise from the engine bay, specifically the belts near the cam gears. It sounds squeaky at idle and almsot like a cricket. I can tell it is coming from the belts in the car, but i dont know what they do. Im bone stock so if anyone could help that would be great. (Car drives fine).
Old Jun 21, 2004, 05:25 PM
Keyser Soze's Avatar
Is your AC on at the time? I know i get some loud noise from the AC fan. dont really know if its really a squeaking type noise but could be what you are hearing
Old Jun 21, 2004, 07:43 PM
k270kmh's Avatar
Me and my friend's EVO develop this same noise. I tried to put some silicone on the belt without success. I guess that this is due to belt adjustment.
BTW, this noise is louder with cold engine, and with A/C off. Ah, could be some dirt because our Evos have a lot of space for incoming air to the engine bay and with this air comes dirt.
Someone solved this problem?
Old Jun 21, 2004, 08:03 PM
the A/C is off
Old Jun 21, 2004, 08:07 PM
jeddi's Avatar
There was a post I created for Ralliart noises. I also get that sort of weird sound too.
Old Jun 21, 2004, 11:09 PM
SSKILLA's Avatar
i have that same noise at idle with the a/c off but i have cams and cam gears...atleast now i know im not going crazy jeeez
Old Jun 22, 2004, 06:00 PM
k270kmh's Avatar
Some suggetion to solve this problem?
Someone?
Old Jun 1, 2005, 02:55 PM
TPetsch's Avatar
BUMP for "I have the same issue"! I have 5500 on my stock MR and have just started hearing idler noise or some other type of pully sound. It's a sound like bearings are just starting to go bad, it's not loud but I'm just wondering if some one has dealt with this issue and has some words of advise. Thanks
Old May 4, 2006, 11:59 PM
ExousiaZion's Avatar
I have the same sound. Not sure what it is but its definately coming from the belt.
Old May 5, 2006, 07:29 AM
saw22's Avatar
I have the same issue too. It started right after I installed BR stage 2. In my case, I suspect its caused by the K&N breather but its hard to tell.
Old May 5, 2006, 07:24 PM
Evotech8's Avatar
I also had this faint "whirling" squeaking sound coming from the engine bay on the passenger side. Drove me nuts for weeks!!
Anyways, I replaced the accessory drive belt with a Goodyear 'gatorback' poly-v belt.
It has this cross-serated design ribs on the belt. Suppose to make it "the quiet belt".
Once I put the new belt on the sqeaking dissappeared!! Not saying this will fix your sqeak, but it fixed mine. After 500 miles and still no sqeak.
P/N: 4060705 / 6PK1790 $30-
Old Nov 14, 2007, 11:40 AM
timmiii's Avatar
I ahve the same thing with my evo, although it starts when the water temp starts the climb. From a dead cold start it'll be quite faint, but when the engine warms up it'll start and it gets loud enough to hear when im sitting in the driver's seat at idle. This happened when my car was stocka round 10,000 miles. It sort of got louder as time passed i guess. Now i'm at 27,200 miles and about to get new belts. If it is the belt I'll post an update.
Old Nov 14, 2007, 11:51 AM
lemmonhead's Avatar
just buy belt spray stuff at walmart or any auto parts store.
Old Nov 14, 2007, 05:43 PM
evolved83's Avatar
i have the same thing that i trying to diagnose... sounds just like a cricket. I put belt "dressing" on with no luck...
anyone else have this problem? mine started it got cold out
Old Dec 26, 2010, 05:43 PM
Ghettofireman's Avatar
I have this problem with my 2003 evo but when the car warms up it stops and I won't here it until the car has to be warmed up
Quick Reply: Squeaking, cricket like noise
