Cat Back vs Turbo Back vs Normal
Old Apr 22, 2004, 11:14 PM
sanfranevo's Avatar
Hi,
Can somebody tell me the difference between a cat-back, turbo-back exhaust? and which is better for EVO.
Old Apr 22, 2004, 11:17 PM
budlong's Avatar
catback- from the cat back to the rear of the car [includes muffler]
turboback-from the turbo back [downpipe and cat back]
use the search button
Old Apr 22, 2004, 11:28 PM
evo_dadi's Avatar
Re: Cat Back vs Turbo Back vs Normal
Originally posted by sanfranevo
Hi,
turboback is the way man mild tune go with a 2.75 piping or if youre gonna go all out go 3inches all the way.also get it tune to get the best out of it.
Old Apr 23, 2004, 01:32 AM
shiv@vishnu's Avatar
To make matters more confusing, we offer two full exhausts-- both of which can be referred to as turbo-backs. One bolts all the way up to the turbo. It can rightfully be called a "turbo-back." The other bolts up to the 02 sensor housing just downstream of the turbo. The latter should technically be called a "dump-back" or "downpipe-back" or "O2 sensor housing-back". Make sense?
shiv
Old Apr 23, 2004, 01:41 AM
sanfranevo's Avatar
so exhaust like the Tanabe or Fujitsubo super Ti should be a cat back exhaust.
btw, what are the two exhausts you described in your post?
Old Apr 23, 2004, 01:49 AM
Yes, if they bolt up to the factory cat, they are cat-backs. The various full exhaust options can bee seen/read about at
http://www.vishnutuning.com/parts_evo.htm
Hope that helps..
cheers,
shiv
Old Apr 23, 2004, 10:43 AM
EVOtook's Avatar
I have Vishnu's dump-back and would recommend it.
Let me know if you want to hear it....I live in the bay area.
Old Apr 23, 2004, 10:49 AM
mifesto's Avatar
i personally think you should stay with catback, highflow cat and a DP.... you loose a marginal power but u can pass emissions
Old Apr 23, 2004, 11:28 AM
LilJapnBoy's Avatar
Just to clarify a little further:
A turboback exhaust system is everything from the turbo all the way to the exhaust tip out the back. This is composed of three main components:
1) downpipe
2) catalytic converter or cat delete pipe (aka test pipe)
3) catback (which also includes muffler and exhaust tip)
A catback exhaust usually consists of two pieces, a long straight pipe that connect to the muffler/exhaust tip.
The whole reason to change out exhaust parts in the first place are for less flow restriction, both in the size of the opening and the straighter piping.
With this said, changing a turboback will give you more gains than a catback. Thus why buying a catback is much cheaper than buying a turboback because it's basically 1 component vs buying 3 components.
robban87
Apr 4, 2017 05:40 AM
CJK
34
Apr 1, 2017 05:24 PM
Jbevoxx
Sep 21, 2016 09:28 PM
razorlab
30
Jul 4, 2010 07:03 AM
FarMer0111
Lancer Engine Tech
Aug 20, 2007 03:00 PM
Quick Reply: Cat Back vs Turbo Back vs Normal
