Special Tool for front stop strut nut?
Old Apr 12, 2004, 01:55 AM
JT-KGY's Avatar
Did anyone use the mitsubishi special tool to install/remove
front top strut nuts? Could anyone tell me what socket size
would I need to move them?
Thanks,
Old Apr 12, 2004, 09:11 AM
Tri-Bar's Avatar
17mm with an Impacted gun. It's real easy is you have access to one.
Old Apr 12, 2004, 09:31 AM
tsi90awd's Avatar
I just used a regular closed-end wrench once the strut was out of the car, and didn't have any problems loosening it.
It might be easier to get the nut loose while the strut is still installed in the car.
Old Apr 12, 2004, 11:37 AM
JT-KGY's Avatar
Impact gun and closed end wrench?
Arent you suppose to loosen up the top nut w/o turning the
center portion of the strut???
Old Apr 13, 2004, 06:29 PM
992gnt's Avatar
An impact will spin the nut off without turning the shaft, no problem. You don't even really need a spring compressor either. I have a spring compressor and it stayed in my toolbox when I installed my Tanabe's.
Old Apr 14, 2004, 03:51 AM
JT-KGY's Avatar
But doesn't shop manual recommend not to use the
impact gun??
Old Apr 14, 2004, 07:51 AM
Tri-Bar's Avatar
They say that so you don't over torque the nut. I have an impact that is only about 50bls, within the spec of the evo. I have been using them of years on struts without any trouble. If you like, you can take the nut off with a impact and install using a socket/ratchet. You may install it with a impact turned down low then check it with a torque wrench. It's only 45bls +/- 7lbs.
Hope this helps.
TS8
11
Jul 19, 2010 11:34 AM
evo585
11
Jul 29, 2009 12:55 PM
TouringBubble
May 5, 2008 01:35 PM
alveezy
Lancer Troubleshooting
Aug 3, 2007 09:59 AM
sjl6102
13
Jun 6, 2005 08:34 AM
Quick Reply: Special Tool for front stop strut nut?
