[FS] 1995 Evo III part out
1995 Mitsubishi Lancer Evolution III GSR, 100,000 kms.
Full parts list up. PM me for more info.
All parts located in Winnpeg, MB, Canada. Will ship at buyer's expense.
Engine parts
4G63 engine longblock (7 bolt). Have video of it running, and compression test showing 120psi cold with a variance of 2-7 psi. Block is cracked at LH engine mounting point, in timing belt area. Could be welded up. $700
Turbocharger, good condition. $300
Coilpacks and new wires $80
Injectors SOLD
New Exeedy stage 1 clutch/pressure plate. Less than 100 miles on it $220
ACT Streetlite flywheel, same mileage as clutch $180
Engine oil cooler SOLD
LH axle shaft extension (transmission to CV shaft) $30
Intake piping, intercooler piping $10-30
Airflow sensor $40
HKS mushroom filter $40
Radiator fans $25 each
Radiator SOLD
Intercooler $80
Turbo to axle exhaust, oem, good flex pipe. $100
Throttle body SOLD
Engine bay accessories
AC compressor $40 - pulley section bent, everything else fine, holds charge
AC lines $30
AC condenser $40
ABS pump $45
Alternator $45
Power steering pump SOLD
Power steering lines, cooler $30
Steering rack, housing cracked, other parts ok $40
Starter $40
Suspension, axle
Front RH KYB Super Special strut $80
Rear LH or RH KYB Super Special shocks $70 each
Tein camber plates front $70 pair
Tein pillowball top hats rear $50 pair
RS*R Ti 2000 springs - 3 only! 2 rear, 1 front $30 each
Front RH lower control arm $45
Steering tie rod inner and outer $45
Swaybar link front $25
Front RH axle $50
Swaybar link rear SOLD
Rear suspension links/arms SOLD
Rear trailing arms/hubs/knuckles SOLD
Parking brake cables SOLD
Rear differential SOLD
Rear swaybar SOLD
Rear axles SOLD
Driveshaft SOLD
Miscellaneous Mechanical
Shift linkage $50
Clutch pedal SOLD
Clutch master cylinder SOLD
Clutch slave cylinder, brand new SOLD
Steering column $30
Handbrake/e-brake $20
Trunk springs for large wing $20
Trunk release cable$10
Fuel door release cable $10
Speedometer cable $25
Power antenna, motor works, mast moves freely, but internal cable broken $20
Rear power window motors/rails $25 each
Power window master switch SOLD
Rear window wiper motor with arm SOLD
Fuel tank $70
Brakes
Brake/gas pedal $30
Brake master cylinder with booster $40
Front calipers $40 each
Rear calipers $35 each
Set of new F&R pads SOLD
Rear rotors, minimal wear SOLD
Body, chassis
Engine under brace, transmission mounts $40
Rear subframe, differential carrier SOLD
OEM Oz wheels, 2 good condition: $60 each, 1 with bent lip $60
Goodyear Ravspec tires, 205/55/15 $200 set of 4
Door weatherstripping $10 each
RH rear tail light $45
RH front corner light $25
Rear floorpan with mounts, bolts, and differential hanger SOLD
Rear window glass $150
Quarter panels (rear fenders) LH or RH $200
Front RH door $200
Rear RH door $200
Upper radiator support $50
Electrical
Turn signal / wiper stalks $35
Misc electrical modules $20-40
Mirror switch, rear wiper switch, other switches $20
Complete front to rear wiring harness $150
MINE'S ECU $350
Fuel pump $60
Drivers windows master switch SOLD
Drivers window motor SOLD
Engine parts
Injectors SOLD
Airflow sensor $40
Radiator SOLD
Intercooler $80
Throttle body SOLD
AC lines $30
AC condenser $40
ABS pump $45
Alternator $45
Starter $40
Suspension, axle
Front RH axle $50
Rear swaybar SOLD
Rear axles SOLD
Driveshaft SOLD
Shift linkage $50
Clutch pedal SOLD
Steering column $30
Fuel tank $70
Brakes
Brake/gas pedal $30
Body, chassis
Front RH door $200
Rear RH door $200
Electrical
MINE'S ECU $350
Fuel pump $60
To everyone who sent me a PM for parts, I apologize for the late reply. I have been away, and did not receive any email notification of messages. If you still need something, let me know!
FS[Northeast]: 18x10.5+15 and 275/35-18 PSS
Turbotastic
For Sale - Wheels / Tires
Jan 3, 2017 08:45 AM
OneCrzyEvo21
Apr 3, 2016 10:09 PM
OneCrzyEvo21
Nov 13, 2015 02:26 AM
