6 Bolt 4G63t DSM Fully built
Whats up guys. Decided to put this up here and give it a shot on the EVO forums. Might not be much interest, but you never know. About 7 years ago, I started to build my GVR4 from the ground up and I made it about half way before I realized that I dumped a lot of coin into it and was only half way done So Im trying to get some of it back.
BLOCK
2.0L 4G63T 6 bolt
.20 over Manley Pistons ceramic and teflon coated
Eagle rods oil resistant coated
FFWDconnection Butcher Crank oil resistant coated
Pro-gram billet main caps
Race bearings all oil resistant coated
Brand new OEM front case, oil pump, timing components...
Balance shaft elimination kit
Oil Squirters blocked off
SCE Titan copper headgasket with built in o-rings
ARP L19 head studs
Fluidamper crank pulley
Ebay oil pan...tried to save money, will never do that again. A lot of modifying for proper fitment, but it worked
Welded -16 AN fittings on water pump and T-stat housing
Every single bolt is brand new from Mitsu
HEAD
One-off AMS CNC ported head
BC valvetrain: springs and retainers, oversized valves, bronze valve guides, low-boy valve seals ect.....
HKS cam gears and Timing belt
BC Cams 288/288
All assembly done by AMS Performance
LONG BLOCK $4000
Very firm on price. Shipping is available, but will cost extra.
Please feel free to spread the word to whom ever. If you have family or friends that are into the dsm game and looking for a motor, please let them know. You can contact me anytime at 484.239.5325 if there are any questions and or details wanted. Prefer text first. Thanks for looking and for the space.
Last couple pics are just showing how awesome it was with the manifolds. This is for the long block only. IT DOES NOT INCLUDE MANIFOLDS OR TURBO.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
BLOCK
2.0L 4G63T 6 bolt
ARP L19 head studs
HEAD
BC Cams 288/288
LONG BLOCK $4000
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Bonezilla
19
May 6, 2014 03:32 PM
Bonezilla
Nov 24, 2013 02:06 PM
Bonezilla
20
Sep 17, 2013 06:34 PM
Bonezilla
Aug 17, 2013 06:25 PM
