OEM Ralliart Part Numbers
Old Mar 30, 2012, 10:55 PM
Raikiri's Avatar
This is just the merged version of all the numbers collected from the previous Part Number Thread
Interior
MZ525607EX - Parking Brake Grip Carbon Fiber/Silver
MZ525608EX - Parking Brake Grip Blue/Silver
MZ360064EX - Silver A/T Pedals
MZ360062EX - Silver M/T Pedals
MZ360063EX - Blue M/T Pedals
MZ360070EX - M/T Shifter Kit
MZ360040EX - "Lancer" Door Scuff Plates
MZ312888 - Lancer Sunshade
MZ503358EX - Rear Seat Cover
MZ312855 - Ralliart Sport Seat Covers
MZ312854 - ES/LS/OZ Sport Seat Covers
MR632497 – Lumbar Seat Adjuster Handle
MR962834 - RA Shift Boot
MN107671XA - RA Shift Knob
MZ525554EX - Silver M/T Evolution Shift Knob
MZ525556EX - Blue M/T Evolution Shift Knob
MZ526952EX - Blue Evo Instrument Cluster Surround
MZ526953EX - Silver Evo Instrument Cluster Surround
MZ312868 - 6 Disc changer
MZ607348EX - Underdash Light kit
MN126920HB - Rear Brake Light *Note This is the part you need to add the third brake light for those who have put on an aftermarket spoiler*
MR629302 - Sportback Cargo Cover
MZ360066EX - White Faced Sport Meter Kit
MN100378XA - Momo Evo Steering Wheel
MN134601 – Cluster LCD Bulb
MR975280 – Speedometer/Tach Bulb
MR444536 – Turn Signal/Fuel/Temp/Warning Bulb
MR568593 – HVAC Blower Motor
MN126738 – Right Front Window Motor
MN126737 – Left Front Window Motor
MR991322 – Right Front Window Regulator
MR991321 – Left Front Window Regulator
MR975089 - Coin Box
MZ598263 - CD Changer Install Kit
MR574731 - Front Mitsubishi Symbol
MB918617 - Ashtray Light
MN185080HA – 06 Ralliart Radio Trim
MR500935 – HVAC Temp Control Decal
MR500932 – HVAC Fan Control Decal
MR568314 – HVAC Mode Control Decal
MR417280 - Dead Pedal
MR206570 - Dead Pedal Cap
MN151111XA - Evo Recaro RH Back Assembly Front Seat
MN151113XA - Evo Recaro RH Bottom Assembly Front Seat
MN151110XA - Evo Recaro LH Back Assembly Front Seat
MN151112XA - Evo Recaro LH Bottom Assembly Front Seat
MN151568 - Evo Instrument Cluster
MR633529 – Interior Carpet
MZ312866 – Ralliart Floormat
MZ312867 – Ralliart Floormat w/o Heater Ducts
MZ514125EX – Trunkmat
MN141364 – S&S Infinity Subwoofer
Exterior
MZ380295EX - Vortex Generator
MZ312849 - Muffler Tip
ALN02YCC01 - Lancer License Plate Frame
MZ575390EX - Mesh Grill Inserts
7450A245 – 06 Ralliart Grill
MZ562635EX - Window Deflector Kit
MZ312911 - Hood Protector
MZ312954 - Ralliart Carbon Fiber Nose Mask W/Front license Plate
MZ312955 - Ralliart Carbon Fiber Nose Mask W/out Front License Plate
MZ312853 - Wheel Lock Set
MR973540 - Antenna Base
MR583214 - Antenna Nut
MR973541 - Antenna Mast
MZ313375 - Labrador Black Pearl Touch up pen
MZ313374 - Diamond white touch up pen
A0002PTY01 - Lightning Yellow touch up pen
ALN04YAD01 - Thunder Grey 04-06 Lancer Body Kit
ALN04YAB01 - Labrador Black Pearl 04-06 Lancer Body Kit
MN154911WA - Ralliart Front Lip
MN154912WA - Ralliart Rear Lip
MN186344xx – 04-05 Ralliart Front Bumper (xx = code for whatever color you need. Parts counter will help you out with that)
MZ312873 - Lancer Car Cover
MZ312861 - Lancer Sunroof Deflector
MR557090 - Ralliart Badge/Decal
MN161939 - Left Ralliart Headlight Housing
MN161940 - Right Ralliart Headlight Housing
MR472551 – Headlight Connector
MN161941 – Left Fog Light Assembly
MN161942 – Right Fog Light Assembly
MN150931 – Left Fog Lamp Bezel
MN150932 – Right Fog Lamp Bezel
MS820964 – Fog Light Bulb
MR991187 – Side Turn Lamp
MB943605 – Turn Signal Connector
MR551466 - Tail light retainer clip (2/side)
MU810528 - Tail light retainer clip (2/side)
MR288150 – Self-Tapping Plastic Body Panel Clips
MU670027 - Crankshaft pulley bolt access plug
MR539528 - Passenger side wheel well vertical splash guard
MR479170 - Driver side wheel well vertical splash guard
MR557680 - Passenger side splash guard under fog light
MR557679 - Driver side splash guard under fog light
MR539599 - Passenger side splash guard under engine
MR974002 - Driver side splash guard under engine
MU000319 - Plastic clip
MN150569 - Driver side wheel well circumference splash guard
MN150570 - Passenger side wheel well circumference splash guard
MR300201 and MR300202 – Left/Right Galant Washer Nozzles
MR520287 – Left Drip Moulding CS7
MR520288 – Right Drip Moulding CS7
MR557029 - Left Drip Moulding CS7W
MR557030 - Right Drip Moulding CS7W
MN100368 - OEM 04-06 Ralliart Wheels
Engine
MZ312865 - Ralliart Engine Block Heater
MZ312863 - Red Hyperground Cables
MZ312864 - Blue Hyperground Cables
MD050316 - Oil Drain Plug
MN156357 – Intake Duct/Scoop
MN156630 – OEM Intake Box Front
MN135296 – OEM Intake Box Rear (MAF Adapter)
MR985187 - Mass Airflow Sensor
MN135985 – Throttle Body
MN143034 – Throttle Body Gasket
MD198128 - O-ring Gasket for Coilpacks
MN143750 - Intake Manifold
MN171073 - Intake Gasket
MR578913 - EGR Valve
MD024719 - PCV Valve
MN163470 – Post-cat OEM O2 Sensor
MD979394 – Engine Gasket Kit
1555A052 – Exhaust Manifold Gasket
MD184303 – Valve Seal
MN183294
MN183293 } - 4G69 Fuel Injectors
MN183292
MN135454 – Fuel Filter
1110A966 – Piston Ring Set
MZ690116 - Oil Filter
MN137240 – Oil Control Valve
MD174581 – Oil Pump Drive Gear
MD174582 – Oil Pump Driven Gear
MN137803 – Oil Pump Case Assembly
MN195078 – Oil Pan
1258A002 - Oil Pressure Sensor
MR994968 - Timing belt
MN137247 - Timing belt tensioner pulley
MR984375 - Timing belt auto-tensioner
MR984778 - Balance shaft belt
MD352473 - Balance shaft belt tensioner pulley
MD979395 - Water pump kit (includes gasket and O-ring)
MN149480 – Water pump pulley
MN149179 – Serpentine Tensioner
MD374877 – Idler Pulley
MN137468 – Knock Sensor
MR515500 Front-ECU (controls headlights and foglights, among other things)
1810A001 – 2.4L Engine Starter
MR450237 – Coolant Reservoir
MD177572 - Coolant Temperature Sensor
MR961214 - Engine Mount Rear 2.4L Manual Transmission
MR554746 - Engine Mount Rear 2.4L Automatic Transmission
NGK-24627 – NGK Front O2 Sensor
NGK-24688 – NGK Rear O2 Sensor
MR578768 - Camshaft Position Sensor
MR985119 - Crankshaft Position Sensor
MR578861 – Accelerator Pedal Position Sensor
MB286961 – Windshield Washer Pump
MR522057 – Windshield Wiper Motor
1355A053 – Radiator Fan Controller
MD315301 – Thermostat
MN149477 – Thermostat Housing
1584A011 – Catalytic Converter
MN153249 – Muffler (Federal)
1571A034 – Muffler (California)
MR281816 – Muffler Hanger x1
MR529673 – Muffler Hanger x2
4455A029 – Power Steering Oil Cooler Tube
Transmission
MR961540 - Transmission Mount
MD103722 – Differential Bearing
MN132370 – Differential Oil Seal
MD746157 – Plastic Cap on Transmission (Holds Output Shaft in place)
2526A001 – Input Shaft Bearing closest to clutch disc
MD717670 – Input Shaft Bearing on farthest from clutch disc
MD040598 – Countershaft Bearing
MD747524 - Clutch Release Fork
Transmission -> Block Fastening Bolts
MF140270 - M10x60
MF140268 - M10x50
MF140266 - M10x40
Brake/Suspension
MN184083 – Front Struts
MN184085 – Rear Shock Absorber
MR510966 - Front Rotors
MB928716 - Rear Rotors
MR519923 - Front Hub - 5 holes
MR527453 - Rear Hub - 5 holes
MR527311 - Driver Front ABS Sensor
MR569781 - Driver Rear ABS Sensor
MR527312 - Passenger Front ABS Sensor
MR407821 - Passenger Rear ABS Sensor
MN156064 - Right Axle
MR580749 – Left Axle
MR491449 - Front Wheel Bearing
MR527453 - Rear Wheel Hub and Bearing (w/ ABS)
4056A037 - Rear Swaybar Endlinks
MR403773 - Rear Swaybar D-Bracket
MR403777 - Rear Swaybar Perch
MR589637 - Rear Swaybar Endlink Bushing
4625A020 - Master Brake Cylinder
Attached Thumbnails OEM Ralliart Part Numbers-asascreen-1-1.jpg   OEM Ralliart Part Numbers-synchroparts.jpg
Old Feb 6, 2014, 04:53 PM
truthdweller's Avatar
Duplicate
Old May 14, 2014, 04:23 AM
turboart's Avatar
Can i get part number for the plastic it the from fender wells
Old May 14, 2014, 09:40 AM
CrAnSwIcK's Avatar
which ones?
Old May 15, 2014, 03:55 AM
turboart's Avatar
Sry i didnt realize i butchered what i said so bad. I need it for the whole front end
Old Jun 19, 2014, 09:42 AM
jag
jag's Avatar
Can I get the part number for Master brake Cylinder?
Old Jun 19, 2014, 10:07 AM
CrAnSwIcK's Avatar
Fender splash guard FL - MN150569
Fender splash guard FR - MN150570
transmission splash guard - MR479170
engine belt side splash guard - MR539528
right fog light splash guard - MR557680
left fog light splash guard - MR557679
Center left (rad support to cross-member) engine cover - MR974002
Center right (rad support to cross-member) engine cover - MR539599
Master cylinder assembly - 4625A020
Old Apr 20, 2015, 10:59 PM
MN124565 - 2004 Lancer Air Conditioner-discharge Hose
Old Oct 25, 2015, 07:33 PM
I need the p/n for the bulb(s) behind the temp control, fan speed, and position knobs.
Edit: MR568787 (86963B)
Old Aug 13, 2016, 04:56 PM
Howulikemyevo's Avatar
Evo 8 timing belt?
Evo 9 timing belt?
Parts #?
Do you know if the Evo 9 timing belt is made out of Kevlar?
I know the Evo 8 timing belt is not.
Old Aug 13, 2016, 06:06 PM
CrAnSwIcK's Avatar
Originally Posted by Howulikemyevo
Evo 8 timing belt?
Evo 9 timing belt?
Parts #?
wrong section dude, but because we FWD lancer owners are such humble and nice people:
Evo 9 OEM timing belt is supposed to be Kevlar...
Evo 8 timing belt : MD326059
Evo 9 timing belt : MN187466 superseded by 1145A038
Old Oct 25, 2016, 02:39 PM
RALLI1's Avatar
Part number for 09 ralliart exhaust manifold
Old Oct 25, 2016, 08:58 PM
CrAnSwIcK's Avatar
My version of ASA doesn't have the catalogue for the 2009+ Lancer Ralliart, only the base lancers and Evo X from 2008 model year...the Evo X manifold part number is 1555A476, and by some crafty google searching I was able to dig it up, it's only one digit off...
09+ Ralliart Exhaust Manifold - 1555A475
Old Nov 22, 2016, 12:56 PM
evo8vz's Avatar
need evo 5 or evo 6 shifter cable
1998-1999
thanks
Old Nov 25, 2016, 05:21 AM
2006_RA's Avatar
1998-1999
thanks
MR388634 for Evo 5 GSR.
If you pm your chassis number or VIN I can confirm it.
blonde
Dec 30, 2023 09:10 AM
evolve_VIII
444
Dec 16, 2020 08:11 PM
evo78
10
Sep 28, 2017 01:35 PM
BLKRalliArt04
Mar 23, 2016 10:23 PM
StreetThisEvo
For Sale - Cars For Sale
11
Mar 6, 2016 05:20 AM
Quick Reply: OEM Ralliart Part Numbers
