E-Spec tests the MAP Ef4 --- 600hp @30psi!!
Old Nov 20, 2011, 09:28 AM
E-Spec@Tach Motor Works's Avatar
Since the previous thread is 15pages long, Cul8tr requested a new thread be started ,,,
( https://www.evolutionm.net/forums/ev...4-evo-8-a.html )
A re-hash on the mods list..
Map EF4 turbo (33psi spike down to 30 psi)
Muse o2 dump
2.4L
GSC s3 cams
Cosworth head ported by headgames
Magnus IM
Full blown tb
fic2150 injectors
e85
E-Spec tuned SD using tephra v7
http://www.youtube.com/watch?v=JO6q1ZJ3L6s
Some food for thought...
We stopped at this low boost level because the clutch started to let loose on the dyno. On a 36psi spike, the tq was too violent.
This 600hp pull still had rich afr's and room for a few more degrees of timing. There's ALOT left in it. My calculations lead me to believe this car would have cleared 660 -700hp.
300tq @ 3700 rpm means this turbo spools amazing -- the runs were started at 3000 rpms!
The wastegate actuator was flawless... On straight wastegate (26-27psi) the car cleared 550hp...
http://s630.photobucket.com/albums/u...t=IMAG4875.jpg
For you pumpgas guys out there-- This turbo is no joke! -- On straight wastegate and 93 octane -- 500hp @ 26-27psi
All in all, I'm happy to see companies pushing the envelope to make this platform the best.
Thanks for viewing.
Old Nov 20, 2011, 09:35 AM
Reserved for more info...
Old Nov 20, 2011, 09:51 AM
ETS Michael's Avatar
Not bad sir
Old Nov 20, 2011, 10:02 AM
CurseDSM's Avatar
Very nice results. I have told people that my car made over 500 on pump and they laughed at me. I believe Tom had the pull and was like yeah we need to do e85. I hope to see more from this, good job guys.
Old Nov 20, 2011, 10:39 AM
Originally Posted by ETS Michael
Not bad sir
Thanks guys!
Old Nov 20, 2011, 10:58 AM
PsychDr. HN$'s Avatar
Nice numbers! The EF4 is quickly becoming a force in the turbo world.
Old Nov 20, 2011, 06:26 PM
Svendiesel's Avatar
Proof for all of the haters out there!
Old Nov 20, 2011, 06:49 PM
Kracka's Avatar
Very nice!
Old Nov 20, 2011, 07:01 PM
I didn't know there were "haters" for or on this product. As anything else, the car community relies on third party testing to confirm results. Time will tell the true story of this unit. I'm sure any of the stock turbo cars in the 10's need only this piece to put them in the 9's. ( Can someone say-- "Marketing Strategy" ---- Dan can be found on Facebook!!! )
Old Nov 20, 2011, 07:27 PM
getsideways's Avatar
This makes me excited for my 2.4\EF combo looks like a perfect setup with a broad powerband.
Itd be great to see what the turbo does on kill mode, what clutch is currently in the car?
Old Nov 20, 2011, 11:46 PM
maperformance's Avatar
Thanks for the post, we definitely appreciate it! You would be surprised by the amount of haters.
Guys if you need one of our frame turbos, you know get a hold of us! If you don't....see below
East Coast;
Tach Motor Works
35-37 Lawson Blvd
Oceanside, NY 11572
516-608-9930
http://tachmotorworks.com/
Midwest/West Coast
Pm
adam@maperformance.com
763-545-3800 ask for Adam
aim - adamatmap
www.turbos.maperformance.com
Old Nov 21, 2011, 02:24 AM
spooled4g64's Avatar
Nice numbers, I would like to see what it would do on a built 2.0L long block.
Old Nov 21, 2011, 05:28 AM
94AWDcoupe's Avatar
proof of what? that its still proving to be a lazy turbo in the spool department?
hasnt proved anything yet to me. yeah its making 300tq by 3800. thats good. but next you have to look how long it takes to make 500tq. what that translates to when you drive the car is very laggy turbo.
call me the biggest hater on the board wont effect my observations one bit. I will still recommend other choices for those who come to me for advice. sorry I am just a straight shooter looking to help others enjoy the hobby as much as I do.
Old Nov 21, 2011, 05:50 AM
BigT's Avatar
What turbo are you trying to compare this to?
Old Nov 21, 2011, 05:55 AM
Let's put your definition of "laggy" on a graph so that we can define this term that is widely used. "Laggy" to me is an opinion based on perspective.
This turbo hit 400tq around 4,250rpm starting the pull at 3,000rpm. At what rpm would you consider hitting 400tq not laggy?
Please post a graph (any graph of any torque/hp curve that you like off of these forums) of what you consider "responsive" and let's compare them and put them into perspective.
Hopefully the graph you post will have a boost plot -- at 4,000rpm this turbo hit 33psi on the higher boost setting. I don't have software that can "overlay" 2 pics, but maybe someone else on here does?
Quick Reply: E-Spec tests the MAP Ef4 --- 600hp @30psi!!
