Autolite XP Irdium Sparkplugs
Old Nov 20, 2011, 06:18 AM
FlatWhite_Evo's Avatar
Was wanting to get a idea on if these plugs are any good and what gap recommended for Evo 8
Old Nov 20, 2011, 09:00 AM
06RedRalli's Avatar
Stick with ngk
Old Nov 20, 2011, 09:14 AM
BoostINurI's Avatar
Nothing but NGK......
Old Nov 20, 2011, 10:56 AM
barneyb's Avatar
NGK have been proven to work. Maybe Autolite are just as good. They can't be proven to work if you don't try them.
Old Nov 20, 2011, 12:25 PM
Boosted Tuning's Avatar
Autolite plugs are usually pretty horrible. Like others have said, stick with NGK (or denso).
Old Nov 20, 2011, 12:35 PM
awdturbo8's Avatar
For the 8 theres no reason to use an iridium plug. Stick ONLY with NGK. Bpr7es I run with a little over 675 hp without a hiccup. Autolite is junk. They made my 07 silverado miss and run like S***
Old Nov 21, 2011, 04:46 AM
TommiM's Avatar
the evo 8 comes with iridium plugs from the factory.
Old Nov 21, 2011, 05:04 AM
EvoLutionized8's Avatar
gap should be determined once you decide on fuel and psi. After that, then tune. I usually start somewhere around .027 and go down to around .023. Run e85, around 40psi. No issues.
And wouldn't say that iridiums aren't necessary.. but they are recommended. the expense is definitely higher, but I guarantee you will change out your plugs more if you run the copper.
Old Nov 21, 2011, 03:58 PM
barneyb's Avatar
I've run plain Jane Autolite plugs from Walmart in my Evo and they were fine.
Old Nov 21, 2011, 04:03 PM
prowakeskater's Avatar
i ran autolites and misfired like a bastard, and so did MANY others. DONT DO IT
Old Nov 21, 2011, 07:19 PM
Just because you had one good experience with them doesnt out weight the 100s of bad experiences with them.
Like "prowakeskater" said, "DONT DO IT"
2.4evo
Jul 14, 2015 09:18 PM
usacchamp
Feb 14, 2014 11:21 AM
EvoRinga
Feb 20, 2011 06:17 AM
bmaga123
Apr 12, 2005 08:51 PM
Quick Reply: Autolite XP Irdium Sparkplugs
