Ralliart Suspension Upgrade
Old Aug 15, 2011, 11:18 AM
NFSLancerRA's Avatar
So, here goes: My next big undertaking for the Ralliart will be a new set of Shocks and Struts. I have decided to go with Koni adjustable dampeners, as the guys at Koni have agreed to develop a set of components for the Ralliart. This is not going to be a simple re-valve hack-job. The internal components of the stock pieces are going to be completely removed and everything is going to be redesigned.
I have no clue what the price is going to be for this upgrade, yet. It will be competitive, though. I will keep this thread updated over the coming weeks as progress is made. I hope to dial-in this upgrade as much as possible to create the ultimate suspension package. It sucks that no-one makes aftermarket shocks and struts for this car. That is about to change.
Old Aug 15, 2011, 11:30 AM
nunyas's Avatar
sweeet! certainly hope this pans out, as i'm sure i'll be needing new shocks within the next 12 months...
Old Aug 15, 2011, 02:38 PM
TOralliart's Avatar
Nice. Hope everything goes smoothly for this.
Old Aug 15, 2011, 03:57 PM
yip
yip's Avatar
Great news! Really looking forward to this
Old Aug 15, 2011, 04:17 PM
p1llar's Avatar
Koni makes solid struts. Hopefully they have them listed around $500.
Old Aug 15, 2011, 04:35 PM
I should know more regarding price as soon as they take a look at the components. Hopefully, this won't be something that breaks the bank.
Old Aug 15, 2011, 08:02 PM
Jasoob's Avatar
Ultimately, wouldn't it still be cheaper just to get basic coilover's?
Old Aug 16, 2011, 07:15 AM
You get what you pay for as far as that is concerned. These will be higher quality.
Old Aug 17, 2011, 06:20 AM
Jasoob's Avatar
Agreed. Are the struts/shocks going to work in conjonction with the OEM springs and aftermarket springs? I plan on putting Swift springs on shortly...
Old Aug 17, 2011, 11:52 AM
I no longer have OEM springs. I have RRM G.R.I.P. springs. These will work with either, but I have to figure out just how much stiffer the springs to be used with these should be in order to maximize the benefit.
Old Aug 17, 2011, 12:47 PM
sstevojr's Avatar
From personal experience, I wouldn't go any lower than 6K (8-10 is best) when contemplating valving. The car is way too heavy to use spring rate less than 6K IMO
Old Aug 17, 2011, 02:34 PM
Originally Posted by sstevojr
From personally experience, I wouldn't go any lower than 6K (8-10 is best) when contemplating valving. The car is way too heavy to use spring rate less than 6K IMO
I will figure that out soon enough. Thanks for the input, though.
Old Aug 17, 2011, 04:45 PM
nunyas's Avatar
I'm nearly certain that none of the available ~drop springs~ will have spring rates higher than 1.5k lbs/in
Old Aug 18, 2011, 10:41 AM
gccruz's Avatar
NFS is taking over the works!!!! run and take cover!
Great job man. keep them coming.
Old Aug 18, 2011, 11:14 AM
sstevojr's Avatar
Aren't the stock springs 3.5k??
Quick Reply: Ralliart Suspension Upgrade
