Whine on cold starts
Old Aug 15, 2011, 08:17 AM
skyseer's Avatar
Sometimes I hear a high pitched whine from the engine bay right after I start my car in the mornings. Whine goes away after 5-10 seconds from start. I think it comes from transmission. What it could be? Car shifts perfectly. Changed trans oil a couple of weeks ago, problem stays...
Old Dec 2, 2011, 02:43 PM
HPEVOX's Avatar
Bump
Mine has gotten louder here leately too since it has gotten colder. Exactly what you're describing I have a video here. It's very faint, but I can make one now where it's much louder due to colder weather. Read a lot of threads with no definite answers.
http://www.youtube.com/watch?v=CCaO9...el_video_title
Old Dec 2, 2011, 02:52 PM
HPEVOX's Avatar
http://www.youtube.com/watch?v=oY9p0...layer_embedded
Mine is now this loud. Super annoying. Not my video lol sorry for the double post, mine just got this loud today.
Old Dec 2, 2011, 07:47 PM
skyseer's Avatar
Mine sounds exactly like that evo in video. Not every morning, but 4-5 times a month.
Whine is rpm dependant. If I press gap pedal, whine changes tone with rpms. Goes away completely after 10-15 seconds from start.
Old Dec 3, 2011, 07:42 AM
HPEVOX's Avatar
Yeah exact same thing mine does. I've read a lot of threads on this and there is no clear answer. Some say serp belt may need replacing and then you have a lot of ppl who say it's perfectly "normal" lol maybe someone with some knowledge will throw in there .02
Old Jan 4, 2012, 07:59 AM
userwave's Avatar
I have it sometimes as well, only when it's very cold, had it every winter, only on cold starts,
other then it being annoying for the 5-8 seconds it last i don't think it's too concerning.
Old Jan 5, 2012, 11:16 AM
SE#202's Avatar
Mine does this as well, however it only does it when its below 0 degrees.
Everyone I've talked to locally seems to think its normal, I haven't heard any adverse affects from it, so I guess it's just another thing to get used to
Old Jan 5, 2012, 02:59 PM
jsmits2689's Avatar
Yea I get that too on cold mornings about 25-30 degrees.. I live in FL lol. Only last for about a minute though.
Old Jan 25, 2012, 10:27 AM
RiG
RiG's Avatar
Mine does this and so did my DSM. I figure its pretty normal because its soo cold out. Im easy on it and dont build any boost until its warmed up and the noise goes away within a couple of minutes of driving.
Old Jan 25, 2012, 07:41 PM
S2K2EVO's Avatar
My ralliart would make a whine only in super cold weather. The X never has.
Old Jan 26, 2012, 10:59 AM
bmxking45's Avatar
My car does this obnoxious noise as well (when its very cold out). I start it up and it does the noise for a few minutes usually. After It warms up a bit it goes away. No idea what it is!
Old Jan 28, 2012, 03:04 PM
RiG
RiG's Avatar
Is it a loud clattering or ticking noise? Maybe you could describe the noise to help us identify it better. Its probably lifter tick that you are describing. What weight oil do you use in the winter? Normally its recommended to go with a little lighter weight oil in teh cold winter.
Old Jan 30, 2012, 02:04 AM
Don'tNeed6th's Avatar
I had pretty much the same thing happen to my car. But it didn't go away within 5-10 seconds, the car would need at least 3 temp bars before the sound went away. Only happened a few times before my first oil change/fluid inspection(3.5k mi), then never came back. I forgot to ask the tech if they noticed anything odd on the first inspection. I talked to him after the second inspection (7k mi) and said everything looked good.
I don't think my issue was temperature based. The coldest it gets in my area is the mid 40's in the winter (good old socal weather).
I have heard rumors of the 2010 model years having overfilled transfer cases from the factory. I talked to another 2010 owner that had his transfer case replaced at 8k miles under warranty.
Old Feb 5, 2012, 07:21 AM
Mr. Move's Avatar
Mine does it too but only on very cold days. Its gotta be a belt or something thats just so cold from sitting around over night then after a few cycles it warms up or loosens up.
Old Feb 5, 2012, 08:23 AM
HudsonFalcon's Avatar
On very cold days (below zero) my X does this as well, it only last a few seconds to a minute and goes away.
It's normal and will not be an issue if you let the car warm up for a bit.
Quick Reply: Whine on cold starts
