Bosch 044, Aeromotive Stealth 340, Deatschwerks DW300, Walbro 255lph Fuel Pump Test
A little while back two new fuel pumps came onto the market; the Aeromotive Stealth 340 and the Deatschwerks DW300. Being the same size as the standard Walbro 255lph and flowing numbers similar to the 044 its needless to say we were very interested. As soon as both pumps were received I flow tested them against the common Walbro 255lph and Bosch 044 and I was pleasantly surprised. The flow chart along with an amperage chart are below. The flow test was done on the same day, same test rig, and used the same fluid. The test was performed at 14V.
At the moment we have all of these pumps in stock.
Deatschwerks DW300
Bosch 044
Walbro 255lph
Deatschwerks DW300
Bosch 044
Walbro 255lph
Very informative. Thanks. Easy to see that the DW and Aeromotive pumps are not the same, and that the amperage requirements for full flow suggest that some people's problems with the DW are probably due to needing a rewire to make the DW (and Aeromotive) flow properly.
I've got a few questions perhaps you can answer:
- Is the Aeromotive any louder than the DW?
- A friend had fuel overrun at idle with the DW. Have you seen this, and would an aftermarket FPR fix this, or does the whole return line need to be replaced?
Scott/AMS
Thank for doing this
For the record, DW did not know AMS was doing this.
We have obviously flowed all of these pumps, as well as others, many times. In our testing against the Aeromotive, our pump flow intersected with the Aero flow at about 80psi and flowed the same above that. Not questioning these results, just sharing what we have tested
Also glad you showed amperage draw, as many don't understand or take that into consideration. We purposely considered amperage draw and kept it lower in exchange for less heat, a bit less flow at lower pressures, in addition to working better with OE wiring. Although, we still do recommend that for full performance at high pressures to hardwire the pump if the OE wiring can not support it.
And since we are EVOM sponsors, we will take the time to point out our 3yr warranty, long term E85 testing, E85 compatibility, correct polarity to match OE wiring, and our applications specific installation kits
We also will be releasing more installation kits very soon
-Mike Deatsch
-Mike Deatsch
I have no idea..lol
Here is where I got it from: http://www.injectedperformance.com/i...owfuelpump.htm
The Aeromotive wasnt noticeably louder than the Deatschwerks, atleast I dont remember it being.
I haven't ran any of these pumps with the stock FPR, in most cases an adjustable FPR is a good investment anyway though. If the pressure cant be brought down at that point you will most likely just have to drill out the suction valve inside the sending unit a little bit to allow more flow. Ive never had to replace a return line.
