What symptoms would a stuck lifter have?
Old Apr 28, 2011, 07:14 AM
CtSilver03Evo's Avatar
I have a loud new ticking noise coming from the exhaust side of my head which I'm thinking is a lifter. I have 272/272 cams in the car and they have been there for a while, but when I was driving my car hard a couple days ago, it backfired and shot a cloud of smoke out.
I've now noticed that I have this unusual noise in the head which I'm almost 100% certain to be the infamous lifter ticket that the Evo's can get.
If the lifter is stuck - what would I expect to see? would this cause breaking up under partial boost?
...I ask because I have another thread going on a similar but separate topic. Please see:
https://www.evolutionm.net/forums/ev...eaking-up.html
Old Apr 28, 2011, 08:01 AM
Pitside's Avatar
If lifter is stuck open, you will have zero compression. Do a compression test.
Old Apr 28, 2011, 08:20 AM
Did one last night. Got 167-169-170-170. I'm thinking maybe the lifter is stuck or intermittently sticking closed and that valve may not be opening. I may pull the valve cover today and see..
Old Apr 28, 2011, 09:44 AM
barneyb's Avatar
Bad lifters make noise - end of story.
Don't try starting it with the valve cover off. You will have oil everywhere.
Old Apr 28, 2011, 09:51 AM
TJPhillips36's Avatar
Most of the time lifters collapse, which in turn causes the valve to not open at all or open only partially. So a compression test will not show the root cause. Take your valve cover off and examine all the lifters. Check for play in the rockers and make sure all the lifters are operating correctly.
Collapsed lifters tend to cause some knock, along with a significant loss (very noticeable) in power.
Old Aug 17, 2013, 07:42 AM
WikdEvo's Avatar
sorry to revive this thread back from the dead but i've got a question concerning stuck lifters.
say the lifter was intermittently sticking. That would cause the valve to open partially correct? In turn, causing richer afr?
Old Aug 17, 2013, 05:58 PM
usernameinuse's Avatar
I am wondering too. I am thinking I have a lifter that may be stuck as well and the AFR at idle has recently went from mid 14s to 11-12 range.
Old Aug 17, 2013, 05:59 PM
WikdEvo's Avatar
I'm the exact same. I went from 15 to 11-12
Old Nov 14, 2014, 02:53 PM
LancerSRT4's Avatar
so uh....was this ever figured out. I'm having a loud noise come from what SEEMS to be the top part of the engine. Gonna do compression test after work today.
It would be nice if people reported what fixed their problem :'(
justboosted02
76
Oct 2, 2019 04:02 PM
mberenis
19
Aug 24, 2016 07:50 AM
navr11
Mar 6, 2016 07:06 PM
Nightbreeze
Feb 28, 2016 10:04 PM
RSMike
13
Feb 21, 2011 10:01 AM
Quick Reply: What symptoms would a stuck lifter have?
