new 2.1 motor oil leak comming from exhaust manifold..
Old Mar 23, 2011, 03:13 PM
kanyonkid's Avatar
i did my normal walk around check, from engine bay to the exhaust during warm up before i drive my car and i noticed light blk smoke comming from the exhaust, so i immediately looked in the engine bay and i saw oil on the vband area of the exhaust mani to turbo, and lower down the pipe at the vband o2 housing to downpipe. So i immediately shut off the car to inspect the leak.. this is what i found.
motor is still in break in less then 300 miles. Anyone else have had this problem?
i assume its the valve seals/piston rings.. maybe head gasket?
any help would be great. thanks.
Old Mar 23, 2011, 03:36 PM
blknblubkrdude's Avatar
I am looking at the pictures, but I can't really get a perspective of what I'm looking at.
If the exhaust manifold has new studs mounted into the head, I know it is possible that oil may be coming from one of those.
Take a mirror and look at the lower mounting points on the exhaust manifold.
Old Mar 23, 2011, 03:46 PM
mayberry's Avatar
This is the first thing that came to my mind. Check that out first. Pull the manifold off and look at the gasket. If there's oil on it, put some loctite on the studs and you'll be fine.
Old Mar 23, 2011, 04:16 PM
kanyonkid's Avatar
the second pic is the o2 housing.. t3 ff kit. Oil is definetly comming from the runners. There is no leak around the exhaust mani gasket where it bolts up to the head.
My question is, is there suppose to be any oil at all comming out with exhaust gas? if so how much oil are we talking about? At idle i have about 2 cap full leaking out after 2 mins.
Old Mar 23, 2011, 06:45 PM
Prshrzd's Avatar
Not to ask a dumb question but what head Gasket are you using I had used a cometic Gasket and mine did the same thing and never again will I use cometic ever. Just my thoughts might be wrong but check and see if the Gasket is leaking?
Old Mar 23, 2011, 09:31 PM
EVO-EVO-EVO's Avatar
Exclamation Process of elimination
Looking at the first picture, if the black area on the "T-Bolt V-Band Clamp" bolt is the oil you are referring to leaking at the "V-Band" and then again on the other side of the turbine housing in the second picture on the down-pipe, I would pull the exhaust manifold off and find what cylinder exhaust port the oil is coming from. By the looks of the relatively large amount of oil coming out of the turbine housing it will be easy to see once the exhaust manifold is off. At that point, look down the port, if it is coming from a valve stem seal failure, then most likely the bowl area around the exhaust valve will be relatively dry and the area of the exhaust port from the valve stem out will be wet with oil. It would be very unlikely that it could be a piston ring issue given the large amount of oil that is leaking. and the fact that you have not mentioned that the Motor was idling rough, indicating a ring/compression problem. Also if you are going to have a problem with a valve seal it usually will occur sooner rather than later after the seals have been replaced.
Good Luck, and sorry that this happened on your new motor.
Old Mar 24, 2011, 09:52 AM
kanyonkid's Avatar
I will be doing a compression test then pulling off the mani fold and the turbo to inspect both. I hope its the turbo spitting out oil instead of the head/motor, since majority is comming from the hotside. , motor idles fine afr's are normal Thnx.
Old Mar 24, 2011, 05:57 PM
BoostWhore's Avatar
DO a compression test first. Depending on your results you may opt to put a cap of oil in the chamber to see if your compression goes up, if it does more than likely its a ring issue.
Secondly if you do not find anything out of the norm, perform a leak down test if they all checks out well then pull the turbo and inspect.
Old May 19, 2011, 07:52 PM
kanyonkid's Avatar
To close this out motor was fine, precision turbos feed needs to be at 12 o'clock. Mine was at 11.. It caused it to leak oil.
SSMCL9
Nov 22, 2016 12:39 PM
Egsik1
For Sale - Part Outs
16
Jun 16, 2016 08:20 AM
nwa7265
11
Aug 17, 2015 06:18 PM
te37drift
11
Feb 22, 2015 02:22 AM
bwanner
Apr 24, 2012 07:39 PM
Quick Reply: new 2.1 motor oil leak comming from exhaust manifold..
