Aggressive Wheels on 2004-2006 Lancer
Old Apr 25, 2012, 02:52 PM
  #271
Raikiri's Avatar
Originally Posted by deathsythe99
on your stock rims? or your xxr's that the g-force are on.
stocks. my XXRs have the s-drives.
Old Apr 26, 2012, 07:55 PM
  #272
deathsythe99's Avatar
do you use the s-drives on the street?
Old Apr 28, 2012, 07:33 PM
  #273
just got my 527's wrapped in nitto nt neogens they are stickey!! not on the car yet as i dont have wheel spacers . Im not sure what size spacer i should go with and how much stress it will put on the studs as im going to hpr in a couple of weeks so i can test out my tires in the corners and do 1/4 mile runs here in 2 weeks so id like to get these in before then or if i could put the tires on as they are with no spacers for a couple of days and be fine.
Old Apr 28, 2012, 08:19 PM
  #274
keithislegit's Avatar
Grab some 3mm spacers all around and I think you'll be fine if your cars fenders are already rolled.
Old Apr 28, 2012, 08:30 PM
  #275
i thought i only needed 5mm for the back to clear the strut
Old Apr 29, 2012, 06:27 PM
  #276
Well to be safe but yeah, 16x8 clears the front if you're not lowered. It only rubs on my mudflap in reverse at full lock. But yeah just a 5mm spacer would be fine. Get a hubcentric 67.1mm one if you do. It cost a bit more but your studs will thank you in the future.
Old Apr 29, 2012, 07:14 PM
  #277
Raikiri's Avatar
3mm in the back should be fine
Old Apr 30, 2012, 06:16 PM
  #278
ok i just bought some and their not the hubcentric spacers do you think my studs will be ok?? i bought the hubcentric rings i just dont know how to install lol if the rings go first or the spacers.
their 5mm btw
Old May 3, 2012, 04:18 PM
  #279
^anyone?
Old May 3, 2012, 04:23 PM
  #280
Raikiri's Avatar
the hubcentric rings just go into the wheel before mounting it onto the car. i would put the spacer on the car then the wheel with the ring in it.
5mm your studs should be fine.
Old May 3, 2012, 06:31 PM
  #281
kapitolralliart's Avatar
Is there anyway to get a 17x7.5 +48 wheel flush? or at least close to flush?
I don't think anyone makes 23mm spacers right? And if they did that would be hell on some studs...lol
Old May 3, 2012, 07:32 PM
  #282
nc_bboy's Avatar
I ran 17x7.5 +45 with 20mm in the rear with 215/45 and I had to roll but they were FLUSH. As for the fronts I needed like 10mm-15mm spacers but ended up selling the wheels before I did. With 17x7.5 +48 I'd recommend 20mm spacers and for the front 15mm spacers. Run 205/40 tires since you said you want stretch. Then roll your fenders to make sure you are not rubbing. Now if you want to avoid big spacers try to get a lower offset if you can.
Also it won't be hell on studs if you get hubcentric spacers. I believe 10mm is where it starts with hubcentric spacers.
One more thing is it also depends on what type of spacers you get.
The bolt on type spacers I believe start at 15mm.
Now if you get the slide on type over your actual studs, if you go pass 5mm you'll have to get extended studs for bigger spacers. So keep that in mind when looking and deciding on which spacers you want.
Old May 3, 2012, 08:01 PM
  #283
Nc_bboy is right on point. Props, that should be sticky'd lol. When messing with studs, always try to get eveything hubcentric (if you can). It keeps the ride comfortable and is less harsh on studs.
Old May 4, 2012, 05:08 PM
  #284
sweet thank you
Old May 5, 2012, 05:58 AM
  #285
213ralliart's Avatar
do i need spacer .. im running 215 35 18 18x7.5 the ride rough though
Quick Reply: Aggressive Wheels on 2004-2006 Lancer
