S-AWC Service Required Light
Old Feb 19, 2011, 04:52 AM
fattytoofat's Avatar
Does anyone know what causes the S-AWC Service Required Light to come on?
I check the resevoir in the trunk and it's full.
This happend while driving at low speeds.
Any help would be great, thanks
Old Feb 19, 2011, 01:00 PM
evokerfes's Avatar
What mods do you have?
Old Feb 19, 2011, 11:45 PM
Sir Kyle's Avatar
Did you have the awc reflash? Were you driving in extreme cold? (less than 30 degrees)
Basically when it gets cold out the fluid becomes too thick and the pump cant flow and burns up. The reflash is supposed to prevent that. Rear end colision could also cause it, that's where the pump is. No matter what, you gotta take it to the dealer. It's under warranty.
Old Feb 20, 2011, 06:55 AM
Mods I have: AP, TBE exhaust.
I think I had a reflash for the AWC a year ago. It has been cold the last few weeks ranging from 0 to -10 degrees celsius.
Is it safe to still drive the car until it can be serviced?
Old Feb 20, 2011, 07:18 PM
Sir Kyle's Avatar
It's safe. I wouldn't recommend getting driftastic tho.
Old Feb 21, 2011, 03:03 PM
Pulled the code using AP
ACD C161e
does anyone know what that means?
Old Feb 24, 2011, 06:27 PM
robdiesel's Avatar
It's your ACD hydraulic pump. Mine just went out 1,700 miles past the warranty. $2,000 to replace. Very disappointing. I've heard of many of these failing. They seem to be mostly in colder climates. I'm very interested to know what caused the failure.
Old Feb 25, 2011, 03:11 AM
Sir Kyle's Avatar
What's your mileage? I thing the powertrain warranty is 5 r/50,000 miles. Not 100% tho.
Old Feb 25, 2011, 04:22 PM
robdiesel's Avatar
Mitsubishi said the pump is not considered part of the drivetrain, so 3yr/36K for it.
Old Feb 25, 2011, 04:54 PM
Sir Kyle's Avatar
aw snap. thanks. But that's lame it's not covered. I have the 7 year/70,000. And thankfully cause my pump went out at 36,6xx no joke. So the extended warranty already paid for itself...
Old Feb 28, 2011, 06:29 AM
xhomm02's Avatar
There are 2 reasons for the pump mulfunction:
1) VERY cold weather makes the oil thick and the pump burns
2) the pump is not shielded against dust and salt going from rear wheels. The mess gets into poorly sealed pump and causes motor malfunction.
My went out in 30k miles...
Old Feb 28, 2011, 08:32 PM
ToFastforU_99's Avatar
Man I hope mine does not go out. I think my warranty just went up. I did notice it coming on a couple of times during the winter but shutting off after i restarted the car. I guess im happy that that is the last winter it will see
Old Feb 28, 2011, 11:03 PM
Ltdanish07's Avatar
Well i just got the dreaded sawc service required light 3 days ago. Im at 42k so im pretty sure my pump is shot.
What a pain in the butt. Finally have everything together for my tune and then bam, another problem.
Old Mar 3, 2011, 01:12 PM
luvboost's Avatar
so is this like a common issue or just a handful of people experiencing the pump going out?
Old Mar 4, 2011, 12:15 PM
JoeA's Avatar
^^^^ Id like to know this also, mine came on just recently but thought it was from my clutch slipping.
Quick Reply: S-AWC Service Required Light
