Steering wheel not lining up!
Well, after A terrible mishap I had with letting someone work on my car and deciding to drop the subframe to do A clutch job. I finished the install myself but when I went for A drive I noticed I did not line up the steering wheel column spines right and now my steering wheel is about A 1/4 turn to the right when it's supposed to be straight. My question is, is there anyway to fix this without having to drop the subframe again?!?!
If you take the bottom half of your dash off under your steering wheel and the bottom cover off the steering wheel you can fix it easily. There are 4 bolts that hold the steering column up. You will have to undo the steering column and pull it off the shaft coming through the firewall. After that, line up the splines and put it back together. Repeat until its straight. After that put a line on the shaft where they meet to mark where its straight. Its FAR easier to drop the subframe on a clutch install is why they did it. Once its marked its easy to line up from there out.
Silver Sponsor
Sounds like a good plan. Personally I put a line on before so I know how many splines I went over, then erase it when finished and make a new line.
Such a pity that some mechanics are so careless.
deeman101
Oct 27, 2014 11:28 PM
theblue
Jul 28, 2008 01:04 PM
