replacing water pump?
Old Jan 13, 2011, 10:16 AM
anthonyrb98's Avatar
i suspect my water pump is leaking, but i can't really tell. there is a VERY small leak on the passenger side that is collecting near the bottom of the crank pulley, then dropping on one of the oil cooler lines, and then finally, dripping on the floor. it is maybe one drop every 15-30min.
i have a 4g64 swap, so i'm assuming that there is a leak where the pump meets the block. i want to check and possibly re-gasket it. can i remove the water pump without removing the timing belt?
Old Jan 13, 2011, 10:23 AM
fre
fre's Avatar
As far as I can remember you can remove the pump without pulling the belt itself. Even if you have to pull the belt it isn't a big deal. All the marks should be there to align the cams and crank. Just verify they are lined up before you pull the belt and ensure they are the same when you put it back on.
The pump itself can be leaking too. I replaced my original pump and the replacement started leaking around the shaft. Had to replace it again.
Old Jan 13, 2011, 10:51 AM
thanks for the info.
Old Jan 13, 2011, 04:19 PM
well, looks like i will be taking the car to english racing for the fix. they are going to install a modified oem water pump instead of using the adapter plate for my 4g64.
Old Jan 14, 2011, 11:09 AM
Registered User
X91EVO's Avatar
hey I always wondered, why dont people just use the 4g64 water pump on the 4g64 block instead of an adapter plate for the 4g63 one?
Old Jan 14, 2011, 11:17 AM
Foxmaster's Avatar
I wonder if the 4g64 water pump would line up with everything. I'm in the process of a 2.4 build and my water pump just went. It would be nice to know if I could get a 64 and all it a day.
Old Jan 14, 2011, 11:28 AM
JohnBradley's Avatar
Offset on the pump is wrong with the pulley attached. We have looked for a bolt on solution and tried everything suggested from every forum. There is no factory pump that bolts on and works with the Evo belt setup.
Old Jan 21, 2011, 09:11 AM
english racing worked their magic and fixed the issue with one of their modified pumps. thanks ER!
EVOclub4
Sep 13, 2012 10:03 AM
AcePitcher11
12
Jun 29, 2011 05:07 PM
rcheung
Jun 16, 2011 07:52 PM
sleeper04
Mar 24, 2010 07:33 PM
cdupont03
Sep 19, 2006 09:15 PM
Quick Reply: replacing water pump?
