Remove Paint From Carbon Fibre
Old Dec 20, 2010, 11:48 AM
roblaza's Avatar
Lightbulb Remove Paint From Carbon Fibre
I bought a CF hood last year for cheap because the guy had painted it flat black. After a solid day and a half of elbow grease and work, I got the carbon back out...Here's my quickie write up... THIS WILL WORK FOR RESTORING FADED CLEARCOAT ON CF ASWELL!!
Tools needed:
1000 grit
1500 grit
2000 grit
Water
Sanding block
Rags and lots of them (t shirt aswell as micro fibre)
Something to prop hood on so it doesnt sit on the gronund (I used the huge box it came in)
Multi speed buffer or an orbital...(I used an orbital cause I didnt have access to a multi speed)
Drill and powerball mini, or powerball cone
Polishing compound
Finnishing waxes
TIME AND ENERGY...
If you dont have a big enough table to put the piece on, i'd highly reccomend knee pads of something to kneel on...
Ok, this is how i got the hood...
What you want to do, is fill the bucket with water, and toss your sand paper in. I started WET SANDING with the 1500 grit, and then moved to the 1000 grit when I realized that the 1500 was taking waaaay too long to remove the paint.
Wet sand with the 1000 grit, BUT PAY VERY CLOSE ATTENTION to what you're removing! Keep a rag handy and wipe the area as you're sanding to keep an eye on your progress. You can actually see the paint come off with every stroke. DO NOT STAY IN ONE SPOT FOR ANY LONGER THAN REQUIRED TO REMOVE THE PAINT!!!!!!! You dont want to go through the clear/gel cause then you're completely screwed.
Once you have the paint off the entire hood, move to the 1500 grit, still being very careful not to sand through the clear/gel! Do the entire hood with the 1500 grit, and then move up to the 2000 for a final wet sand. The 2000 grit will get rid of any little scratches that may have been caused by the 1000 or 1500 grits. I tried to stay sanding in one direction at a time.
When you think you've finnished with the 2000 grit, it's time to break out the buffer and polishing compound. FIRST, wash the hood off with soap and water, and then dry it.
Apply the compound to the buffing pad and not the hood, and SLOWLY work it onto the hood at LOW RPMS! Once you arent going to splatter the compound everywhere, you can turn up the RPM's to about 3500, but be sure to keep the buffer constantly moving to avoid burning through. Do the entire hood like this. Again, I used an orbital just because i didnt have access to a multi speed buffer...
When you finnish with the compound, wash the hood again aswell as the buffing pad, OR if you have another pad, use that. Apply the wax/polish in the same fashion as the compound, and go untill there's a slight haze on the hood. Do the whole hood, (this is where the powerball mini/ or the powerball cone comes into play if you're doing a hood with curves and corners like mine). Use the microfibre rag to wipe excess wax off the hood, and then apply one more coat of wax by hand, as this will help to remove any swirl marks from the buffer or orbital. Let it haze and remove it just like you would the rest of the car.
Sstand back and admire you're hard work.
Old Dec 20, 2010, 11:54 AM
Tiradocc's Avatar
Good write up!
Old Dec 20, 2010, 11:57 AM
Alexl08's Avatar
i need to do this to mine because of cloudiness
Old Dec 20, 2010, 12:01 PM
foam's Avatar
Wow, I might have to think about this on my Evo!
Old Dec 21, 2010, 12:52 PM
Flip's Avatar
dude, very nice write up, kudos to you sir. i have the same hood, thing looks brand new on your RA.
-FLip
Old Dec 21, 2010, 01:51 PM
Alexl08's Avatar
yeah it really does look brand new i think he is lieing a just bought a new one once he gave up all that hard work jkjk good work man
Old Dec 21, 2010, 08:08 PM
deylag's Avatar
Wait that cf hood looks brand new. Why did the seller decide to paint it flat black if the carbon fiber was all good?
Old Dec 21, 2010, 08:31 PM
roblaza's Avatar
thanks for all the positive comments! hope i could help anyone looking to refinish their carbon...
honestly, i have no idea. i got it from a guy on another board for cheap, and truthfully, it has a few cracks in the gel that i need to attempt to do something with over the winter before it goes back on in the spring, and i'm going to get it re-cleared aswell to help bring out the shine and help protect it a little better.
Old Dec 22, 2010, 11:44 AM
nekkidlad's Avatar
looks sweet man
at least in the picture it just looks brand new...
ps i like how the license plate is blurred in the one pic but not the other...
o well, now we can spot u and u if we see you...not that we wont spot the bright red and cf hood...
Old Dec 22, 2010, 04:12 PM
squid267's Avatar
does this work if i want to take the clear coat off my cf hood and redo it?
Old Dec 22, 2010, 06:47 PM
roblaza's Avatar
it will yes, but you have to be extremely careful that you do not take too much off and hit the carbon layer itself... give it a wet sand with the 1500 lightly and then go to the 2000. MAKE SURE NOT TO HIT THE CARBON!!!! give it a good buff and get it cleared.
Old Dec 29, 2010, 03:37 PM
father04co's Avatar
long time ago, i got an old evo8 wing for dirt cheap off ebay(50$). The only thing was the clear going out like TONS of true evo wing. I sanded, painted, cleared and it looks awesome now!!! (to redo it, id put more clear (ive applied half a can and a year later with winter and everything, paint is starting to peel away)..... since then, im riding wingless and im loving it since then!!!! Here's my thread i created, might help you https://www.evolutionm.net/forums/04...re-making.html
edit: nice write-up and awesome job on the hood!!!!!
Old Dec 29, 2010, 05:16 PM
Ralliart_on_LSD's Avatar
Very good write up. And you did a great job.
My carbon fiber hood is in pretty bad shape. It was never garage kept. And when the motor was blown up, it sat at my house under a cheap tarp for a year. so the finish on the CF is fadding pretty bad. Probably going to do the same. Sand down the clear coat, and than get it redone. think it'll work? Asking, because what you did was sand down the paint, and keep the clear coat. I wasnt to re-do the clear coat...
thanks.
Old Dec 29, 2010, 05:26 PM
father04co's Avatar
(on my part i sanded paint+clear and re-did it) You cando yourself the clear but im not so sure how it would look on a hood. If it was my hood, i'd sand it and go to a paint shop get it clear
Old Dec 29, 2010, 08:13 PM
roblaza's Avatar
Ya, it will work. You don't need to take the Lear completely off, just enough to get rid if the imperfections, then have it cleared again
Quick Reply: Remove Paint From Carbon Fibre
