Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
**How to install the MAGNUS master cylinder upgrade**
Old Sep 17, 2010, 09:08 AM
hollywood_X's Avatar
Exclamation **How to install the MAGNUS master cylinder upgrade**
https://docs.google.com/leaf?id=0B2V...ut=list&num=50
Hopes this helps
Old Sep 17, 2010, 12:48 PM
EVO X 6950's Avatar
Originally Posted by hollywood_X
Old Sep 17, 2010, 04:45 PM
ugakirk's Avatar
Has anyone installed the Magnus CMC? How the feedback?
Old Sep 18, 2010, 08:40 AM
You may get more feedback from the other forum
Old May 14, 2011, 12:25 AM
Deepseadiver's Avatar
In the last picture of the "HOW TO" is that with the clutch pedal down or up?
Old May 16, 2011, 07:16 AM
It's up, when you install the L shaped piece your setting your pedal height.
Or are you talking about the slave and fork picture? If it looks funny its because the TOB isn't engaged yet.
Old Jun 2, 2011, 11:28 AM
blincoln423's Avatar
how long did it take? is the installation similer to the SSP?
Old Jun 25, 2011, 12:27 AM
tephra's Avatar
doing mine right now..
mine is RHD so its slightly different.. the original hard pipe is REALLY long and goes behind all the other hard pipes so I think its going to be bent when coming off oh well
first question, do you think a carbide grinder for a dremel will be enough to get those nubs off?
Old Jun 25, 2011, 07:13 AM
It will probably take a lot longer to do it that way. Also some people have been having good success with the rocking method.
Old Jun 25, 2011, 07:31 AM
tephra's Avatar
yeh Jon@Cobb Socal suggested that..
ill give it a whirl tomorrow
Old Jun 26, 2011, 08:04 AM
tephra's Avatar
do you think you can take off the brake booster WITHOUT taking off the brake MC?
as long as your careful with the hardlines that is..
Old Jun 26, 2011, 08:24 AM
IIRC thats what I did, I just bent the tubing back a hair... maybe
Old Jun 26, 2011, 08:26 AM
tephra's Avatar
well i'm going to give the bendy method another go tomorrow... but it looks like its just going to snap the stud off and not break the spot welds...
Old Jun 26, 2011, 08:46 PM
guswaym's Avatar
excellent read
Old Jun 26, 2011, 09:23 PM
tephra's Avatar
ok the bendy/wiggle method was a fail for me..
i just snapped the stud in half...
maybe they put extra effort on my spot welds haha
so now I have to remove my brake booster and drill the ****** out from the backside...
Hollywood - is it best to drain the brake master before unhooking the brake lines? or will veyr little fluid come out if I just unscrew them?
Quick Reply: **How to install the MAGNUS master cylinder upgrade**
