Fuel Floater reading wrong, AEM EMS issue? anyone
Old Aug 14, 2010, 07:45 PM
ezzey's Avatar
I've done some research on here and google (other forums), but haven't really found any answer.
Last week my fuel level indicator on the dash got stuck at 1/4 tank. After shutting the car off, and back on, it was working again.
The other day i parked with a little less then 1/4 tank, and in the morning when i started her up, it was way below past the empty mark with the light on, but was only able to fill up about 35 Liter's, and the tank is 55 Liter's. So i obviously had gas.
Found some information where the AEM EMS could be the issue and there is something you can disconnect on the harness in order to minimize the problem, but there wasn't a direct solution, and i can't seem to find anything.
Can anyone shed some light....
dj
Old Aug 14, 2010, 07:57 PM
Ev0ikon's Avatar
Did you open up and pump assembly and see if the floater itself is not acting funny?
Old Aug 14, 2010, 09:09 PM
ezzey's Avatar
nope, ill try it in the morning, how do i test this thing anyway?
fuel pump assym. under seat rear passenger right?
dj
Old Aug 14, 2010, 09:16 PM
Fast_Freddie's Avatar
Mine did this out of the blue on stock ecu a few weeks ago, I had to remove it 3 times to get it working again... haven't had a problem since
Old Aug 14, 2010, 11:20 PM
ezzey's Avatar
you removed it 3 times? removed and replaced or...
how can this be tested?
Old Aug 14, 2010, 11:47 PM
Ev0ikon's Avatar
Yeah it's right under the driver's side read seat. Take a bit of manuvering/turning to get the assembly out. But if you looks at the floater you will understand. Just bend it straight out a bit.
Old Aug 15, 2010, 10:23 AM
ezzey's Avatar
Originally Posted by Derock2gspyder
ya id say the floater got bent up a little! just pull it and check it out!
Just watched a video on it, pressy easy stuff. But since i just filled up yesturday morning ill wait a few days so i dont get high off all the fumes, heh
tx for the info
dj
Timmay81
Nov 7, 2020 04:49 AM
twisty
Jan 7, 2017 12:16 PM
ezzey
Jul 19, 2012 07:41 PM
jessmanEVO
Mar 2, 2012 10:32 PM
El Boricua
AEM EMS
Jun 13, 2009 12:57 PM
Quick Reply: Fuel Floater reading wrong, AEM EMS issue? anyone
