How high is the stock rev limiter?
Old Aug 3, 2010, 09:04 PM
tlsole's Avatar
Hey guys,
Well this may a dumb question but, how high is the stock rev limiter at? I ask because i was curious on how high it can go and it went up to ~7500 in first gear and in neutral. I know redline on the guage starts at 7000, but can it over rev that much?? I just bought the car pre-owned at the dealer and now wondering if its bone stock or is it already flashed by someone else? I plan to go to the dealer tomorrow to get the latest flash and im thinkin if i got a custom reflash already then screw it. Reason why i wanted the latest reflash from is cause i was experiencing stuttering in high rpm's, weird idle etc and figured id bring it in. But tonight i floored it and it seems fine, no stutterings and not to much weird idle (itll only bounce slightly once in awhile).. any clue?
Thanks!
Edit: If you got this far, sorry for the long read! Im a noob
Old Aug 3, 2010, 09:21 PM
►EvolutionX◄'s Avatar
7500
Old Aug 3, 2010, 09:23 PM
tlsole's Avatar
Thanks bro. So i still should go get the latest flash .
Mods if you can delete this thread, sorry.
Old Aug 4, 2010, 04:21 AM
EvoM Administrator
Noize's Avatar
7599 per Ecuflash
Old Aug 4, 2010, 05:04 PM
tlsole's Avatar
Thanks guys. One last question, is it bad to rev pass 7k? Where the redline starts? Or is it ok to shift around 7500 on a stock car?
Old Aug 4, 2010, 06:52 PM
Srt-4 Turbo 7's Avatar
If your still on the stock turbo it is absolutely pointless to rev that high bc power falls off way before then. I would shift at 6,800rpms on the stock turbo. It is ok to rev to 7,500 rpms on the stock cams. If you change the cams I would do head studs and valve springs to rev that high.
Old Aug 4, 2010, 07:26 PM
tlsole's Avatar
Yeah you are right. The factory turbo just doesn't pull that hard up top haha..Maybe after a tune it'll be better..
Old Aug 4, 2010, 07:30 PM
widge's Avatar
7606rpm
Ive got stock turbo with cams and shift around 6800-6900 as others have said its pointless to keep revving
Old Aug 4, 2010, 07:53 PM
Golden's Avatar
The ECU cuts fuel at 7599 RPM and restores fuel at 7396. This is how the engine seems to bounce off the Rev Limiter.
Old Aug 5, 2010, 12:29 AM
EvoM Administrator
Noize's Avatar
Originally Posted by widge
7606rpm
7606 is an Evo VIII and IX 4G63. 7599 is the 4B11 Evo X. You're in the X section.
DormantBeast
13
Jul 9, 2017 07:38 AM
lanzerralliart
61
Feb 15, 2014 02:15 PM
TrippinKent
Apr 11, 2013 12:31 AM
marcouxa1
Lancer Engine Management / Tuning Forums
Jun 5, 2012 01:07 PM
AAEVOX
18
Sep 27, 2010 02:11 PM
Quick Reply: How high is the stock rev limiter?
