What do i need to run E85
Old Jul 27, 2010, 05:28 AM
superk1980's Avatar
just curious what i need to do to run E85. current mods on car- stock top and bottom. 1000cc Rc injectors. single 255 pump. tomei 280 cams. GSC springs and retainer. APR head studs and Greddy T67 turbo kit
Old Jul 27, 2010, 05:30 AM
06MRV8Killer's Avatar
I think that you just need to run bigger injectors, I have a set of FIC 1450's if your interested check out my post...
Old Jul 27, 2010, 06:55 AM
Sinbig's Avatar
There's gotta be some sort of conversion kit. You can't just dump e85 in your tank and drive off into the sunset.
Old Jul 27, 2010, 07:03 AM
TouringBubble's Avatar
You would need more injector for that turbo/cams, then tuning for E85 and that's all.
And yes, assuming you have the capability to flow enough fuel (pump and injector upgrades), then you can almost just dump in E85 and go. The only issue I know of on the Evos is with the short fuel lines in the Evo X's fuel pump assembly. They need to be replaced with standard fuel line.
You also need to use a stock fuel sock on the fuel pump. The sock that comes with the Walboro install kit (soft and fiberous) likes to break down. The stock sock (more of a synthetic mesh) does not.
Old Jul 27, 2010, 07:54 AM
buchnerj's Avatar
Search and you will find all your answers. You will need a bigger fuel pump, most likely a walbro, injectors AT LEAST 1000cc, a boost controller of some sort to adjust your boost. It is a good idea to put in some head studs also, while you have it ripped apart as good insurance.
There are a million threads on E-85, 98% of them have the mod list needed to switch. It varies, but you will need a larger pump, injectors at least to swap.
Old Jul 27, 2010, 08:09 AM
RockmanX's Avatar
buchnerj you got pm buddy
Old Jul 27, 2010, 10:47 AM
superk1980's Avatar
Buchnerj, everything you mentioned i already have on my car as i mentioned in the beginning. All, So if i;m understanding correctly all i would need is bigger injectors say 1450cc and a tune and i should be good? Thanks for the help guys
Old Jul 27, 2010, 10:54 AM
/\ Yup
Old Jul 27, 2010, 05:13 PM
SmurfZilla's Avatar
Wealth of knowledge in the Alternative fuel section. You will get an answer to anything you ask in that section. Best performance mod you can do to your car if you have it available.
Old Jul 27, 2010, 05:21 PM
evonam07's Avatar
1000cc injector r fine... especially if ur runing stock turbo..
Old Jul 27, 2010, 05:45 PM
snailman83's Avatar
^x2 no need for 1400cc injectors unless you plan to go big in the future
Old Jul 27, 2010, 06:23 PM
You guys should maybe read his post before replying ... he already has a big turbo.
Old Jul 27, 2010, 06:42 PM
EvoJoeIX's Avatar
yes you can
all you would need is a tune for the E85
of course you need the supporting mods for the motor( big injectors, double pumper, fuel rail, ect.)
its not like you have to change anything to make it e85 compatable. anything that can handle pump gas can handle e85
Old Jul 27, 2010, 10:01 PM
italianevo88's Avatar
really, I guess everyone has been lying
Old Jul 27, 2010, 10:09 PM
superk1980's Avatar
nice, can't wait to see the difference after i pick up some new injectors and get a tune..thanks all and i also taught u needed some kind of conversion kit also so good knowledge for myself
Quick Reply: What do i need to run E85
