Car died while driving now it wont start!! HElp!!!
Old Jul 3, 2010, 05:49 PM
iM.So.EvO's Avatar
Unhappy Car died while driving now it wont start!! HElp!!!
So i was just driving normally and all of the sudden my car turns off. i roll over the edge and i try to turn it back on but it wont start! i mean it will turn but it wont start so i dont kno what the problem is. Plz help!!!!
Old Jul 3, 2010, 05:55 PM
TurboTim06's Avatar
is it cranking over? ...check fuel pressure?
Old Jul 3, 2010, 05:57 PM
FedEvo8's Avatar
Check fuses, fuel pump, any CELs?
What are your mods?
Old Jul 3, 2010, 06:01 PM
4RETECH's Avatar
Check for fuel pressure and spark. If you got that, then check compression.
Old Jul 3, 2010, 06:49 PM
heavens turbo's Avatar
might wanna check your crank sensor too. when those go bad, it also has the syptoms of random dying and crank no start. should have a code stored. good luck!
Old Jul 3, 2010, 06:57 PM
Skylineracer's Avatar
Location: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
check fuses.
Old Jul 3, 2010, 07:12 PM
iM.So.EvO's Avatar
Unhappy
well guys all i did was bolt ons and i rasied my boost a couple of pounds. ive been drivin it just fine for a month this just happened. i also just changed my spark plugs just now and its still not turnin on, its crankin but not startin up.
Old Jul 3, 2010, 08:16 PM
goldenEvo's Avatar
Check for any codes, you may have a bad relay for the pcm. Last resort, bring it a reputable dealer.
Old Jul 3, 2010, 08:19 PM
chinto's Avatar
ic pipe pop off?
Old Jul 3, 2010, 09:43 PM
TurboTim06's Avatar
have you checked for fuel pressure yet?
Old Jul 4, 2010, 02:22 AM
iM.So.EvO's Avatar
i will chk all of the above tommrow, thx guys ill keep u updated. thx
Old Jul 4, 2010, 02:55 AM
Evoryder's Avatar
P0113 and P0335 should be the stored codes.(connect a proper OBD-II scanner)
Your crank angle sensor is dead.
Old Jul 4, 2010, 10:11 AM
bboy_RES's Avatar
check your ignition fuse. it believe it's a 15 or 20 amp fuse under the hood. this happened to me a couple months ago. i drove to school and then after school my car wouldn't start. i checked my fuses and my ignition fuse was blown. i replaced it and then my car still wouldn't start. what i didnt do is recheck the ignition fuse again. apparently it kept blowing because i had a short. once i fixed that the ignition fuse stopped blowing.
Old Jul 4, 2010, 12:17 PM
k1cker's Avatar
also check your ECU, i had some problems with power supplies on it.
Old Jul 4, 2010, 12:26 PM
EvoFredo's Avatar
check your battery. i had a mini battery that would want to crank but not enough power. the underside had a crack in it . good luck
Quick Reply: Car died while driving now it wont start!! HElp!!!
