Break pedal shudders & thudding sound on breaking
Old Jun 5, 2010, 08:33 PM
Christoforo's Avatar
So today after driving an hour to LA for class, while driving in the city when I would do medium to heavy braking from above 30-40mph I would hear a thudding sound and my brake pedal would shudder along with it.
Something simmilar happened when one of my lugnuts wasn't tightened all the way and became loose, so I pulled over and checked the front two wheels, all the lugnuts seemed to be tight and so I continued driving.
I made it back home and everything else seemed fine.
What could cause this?
Old Jun 5, 2010, 08:38 PM
evoben24's Avatar
check your brake pads and rotors make sure their not worn out
Old Jun 5, 2010, 08:48 PM
It doesn't seem like a brake pad issue, I suppose maybe it could be the rotors.. I put new ones on less than a year ago though so I find that hard to believe.
Old Jun 6, 2010, 04:01 PM
EvoM Administrator
otter's Avatar
Can be a number of things. Uneven pad transfer, failing wheel bearing, rust buildup on the hub, etc. Get your rotors turned then see if it comes back.
Old Jun 6, 2010, 07:05 PM
Thomar's Avatar
did you perform a proper bed-in procedure?
Old Jun 6, 2010, 07:47 PM
I did bed the brakes/rotors in when I installed them, is there any way to further test to see if its a wheel bearing or other non-pad/rotor related issue? I've been driving normally and just using as little brake as possible and everything seems fine, so maybe it is uneven pad transfer..
Old Jun 6, 2010, 08:00 PM
EvoM Administrator
otter's Avatar
Turn the rotor. If it comes back, then it's something else. If it doesn't, then it was just pad transfer.
fireroasted
Nov 8, 2012 11:20 PM
catman78
18
May 7, 2011 06:13 PM
phatman2600
19
Dec 19, 2005 06:19 PM
zstryder
28
Aug 15, 2005 09:19 AM
HoustonEvoVIII
15
Feb 11, 2004 08:09 PM
Quick Reply: Break pedal shudders & thudding sound on breaking
