CVT Transmission "Slow down" Warning?
Old Mar 30, 2010, 06:49 PM
Fredj's Avatar
Engine: 4B11
Mileage: 14000km
when driving at the speed of 210 km, "Slow down" Warning appear on screen until slow down.... slow down to 0km and then just disappears!!
My question is, does this warning mean bad things coming soon, like destroy my CVT?
What should I do about this?
Any help would be appreciated
regards
Old Mar 30, 2010, 07:36 PM
lancer0220's Avatar
probably just means your cvt fluid was heating up to max temperatures...
Old Mar 30, 2010, 07:38 PM
LanceR_11's Avatar
Could be that the tranny is overheating because at that speed i would assume you are on a very high rpm.. why in the world are you doing at 210 km/h? I believe that is almost about 120+mph..
Old Mar 30, 2010, 08:10 PM
evo_soul's Avatar
lancer0220 is right, operating your car at that speed will raise the temp of everything. CVT fluid would take longer but its going to start cooking your internals. If you do that hard driving often, i would think about changing your CVT fluid and engine oil alot more often.
I assume you are tracking this car, if thats the case, you should consider a very large transmission cooler.
Old Mar 31, 2010, 12:38 PM
lancer0220's Avatar
how long were you driving that fast ? what were you doing before you hit that top speed , were you in D or sport mode ?
Old Mar 31, 2010, 06:06 PM
Fredj's Avatar
Hello everybody, thanks a lot for your reply
1. More than 15 minutes
2. Driving in the Desert!!!
3. INVECS-III, Sport mode
I'd like to know what will happen to the CVT, and "Slow down" Warning, is it too dangerous?
do i need to go to mitsubishi service center?
Old Mar 31, 2010, 07:55 PM
evo_soul's Avatar
it means you brought your fluid and transmission into a temperature range that is not recommended. You reduce the life of the fluid greatly when you do this. I highly recommend you consider changing your fluid at the severe change interval.
To put this in perspective. high temps in the transmission isnt that easy to do, there is alot of fluid in there and most of the parts doing the work are submerged in fluid all the time. if you had that warning come up. it means you were seriously running it hard.
Old Apr 1, 2010, 01:13 PM
Fredj's Avatar
thanks evo_soul
Someone tell me "don't replace your automatic transmission fluid", is it true?
Old Apr 1, 2010, 01:51 PM
evo_soul's Avatar
Originally Posted by Fredj
thanks evo_soul
dont replace it with Automatic fluid. ONLY USE approved MITSUBISHI CVT fluid. Another brand which is ok is the ENEOS CVT fluid. Dont use Auto or Manual fluid, or your transmission will be dead in a few minutes.
Old Apr 1, 2010, 02:07 PM
DrivinMissDaisy's Avatar
I have got my fluid hot before and you could smell it burning just by driving through the canyon in sport mode doing tons of shifting. I have never got that warning. Maybe the tranny could take a lot more abuse then what I do to it? Who know.
Old Apr 1, 2010, 04:28 PM
Fredj's Avatar
Canyon, Canyon, This actually happened to me!! Is this the reason?!
yet another question about CVT's longevity, what's the longevity of CVT Transmission, in km??
Old Apr 5, 2010, 10:27 PM
CamShaft's Avatar
No one knows how long the CVT transmissions last, especially this one. With regular maintenance and NOT overheating it, then a long time... Take it easy on your car, if you beat it up expect it to break, but don't expect mitsu to cover it under warranty due to abuse!
Old Apr 18, 2010, 11:11 PM
TutMatt3's Avatar
you gotta remember that the CVT tranny can be weak, as other have stated
You dont want to push it too far to the max, or you might be needing to replace it soon
Old Apr 19, 2010, 02:16 AM
Fredj's Avatar
Thank you all so much for your support
i buy Lancer GT, just for the INVECS-III sport mode, but to me nothing's better/sport, than manual transmission..trust me!
My Lancer - latest news:i just had my fog light replaced because it was cracked, i don't know why!!
Regards
Old Apr 19, 2010, 02:53 AM
skyblas's Avatar
any pic?
Quick Reply: CVT Transmission "Slow down" Warning?
