BEATRUSH front member support bars install/review!!
Old Feb 13, 2010, 08:31 PM
halfnhalf83's Avatar
Well, ive installed a whole slew of beatrush products and there arent too many install/reviews of them. Mostly because people opt to buy other brands or similar products that do the same function.
Anyhow just thought id share...
For the install items you will need
3/8 ratchet (or whatever you have around)
19mm socket
12mm socket
12 closed/open ended wrench
extension if you must
allen/hex key for beatrush provided bolts
First, jack the front end up and get out your jackstands (safety first!)
Then proceed to take out the 19mm main bolt on the lower control arm (towards rear)
then you can take out the qty:2 12mm bolts that you will reuse to mount the support bars ( see picture) note: you will need to take out the 12mm bolt on the inside of the frame rail area, not the one on the outside as seen in the picture. Also...on the drivers side i found it better to just use a open ended 12mm wrench since there are hard lines that run right by the bolt head on the inside of the frame rail.
Now you will replace one of the 12mm bolts with the provided beatrush bolt. i found it easier to get this one started first...then i proceeded to put the main 19mm control arm back in. Note: do not tighten anything down all the way until you have at least started all 3 bolts.
i used some of my spare Hondalock (blue) on the threads just so nothing backs out due to excessive vibrations from the semi-solid beatrush front mount and propellar shaft bushings. Its not needed by any means but i just like it for a little extra piece of mind. plus its good against vibration and moisture. haha!
Finished with both support bars and front performance bar installed!
Ill come back and update after i drive it a bit more for the review...stay tuned! lol
Old Aug 24, 2010, 05:54 PM
2StepsAhead's Avatar
Anything ever come of this? Saw a few people running these, wondering if they are worthwhile.
Old Aug 24, 2010, 06:34 PM
TurboTim06's Avatar
yea any update on this?
Old Aug 25, 2010, 06:56 AM
ElectrIX Blue's Avatar
mod plz add this to the how to section
Old Aug 25, 2010, 08:02 PM
TommiM's Avatar
maybe he wasnt happy with it?
Old Oct 3, 2011, 01:03 AM
Rmeister007's Avatar
Sounds like he didn't notice a thing if he never responded. Because of this, I think I'll pass on this item and go with the cusco instead.
Old Oct 7, 2011, 12:06 AM
sujinX's Avatar
these are almost exactly like the cusco, if these dont do $hit then what makes you think the cusco's will? its a solid brace, theres not much else u can do to change it.
Old Oct 7, 2011, 04:11 AM
Smike's Avatar
Or pass on both? Mostly added weight. Evo is a stiff platform.
Old Oct 8, 2011, 12:04 AM
Well, there's more options with the Cusco. I was referring to the Cusco setup, not the exact replacement.
Old Oct 11, 2015, 06:33 PM
mrfred's Avatar
Interesting lack of followup post from the OP. He must still be evaluating...
Old Oct 12, 2015, 10:35 PM
codgi's Avatar
if it's like the Cusco setup, those support bars will make you hate bumps in the road....
Old Oct 13, 2015, 06:35 AM
mrfred's Avatar
really? i figured they'd have little-to-no effect on anything.
Old Oct 14, 2015, 12:04 AM
codgi's Avatar
The first night I touched what should be a reasonable pothole with those on I thought the suspension had broke. You don't notice it with time but it does make that area less forgiving. Notice I didn't say the car noticeably handled better.
Old Oct 14, 2015, 09:01 AM
mrfred's Avatar
I've got a pair in the mail, so I guess I'll find out for myself.
anthonypazsd
134
Jan 19, 2024 11:48 PM
Faust
76
Nov 6, 2018 06:47 PM
ardevas09
37
Aug 10, 2017 05:51 PM
ardevas09
42
Sep 28, 2016 06:53 AM
EGbeater
Jan 16, 2016 04:14 PM
Quick Reply: BEATRUSH front member support bars install/review!!
