My Subwoofer all of a sudden just got very quiet????
Old Feb 3, 2010, 08:01 PM
High_PSI's Avatar
I have a Memphis Audio Single Channel Amp, I believe it is 250 Watts RMS powering a Single Orion 10" sub. Just today all of a sudden it went quiet, VERY quiet. I have to turn the gain all the way up to hear it and the sound mixer thingy past 80% to get anything out of it.
Also I noticed a little more engine noise and when I push in my cigarette lighter I hear a pop from the the sub, any ideas?
Old Feb 3, 2010, 08:11 PM
4xforce's Avatar
My guess is that the amp is shot. I would be very certain that all the connections are secure especially power connections. All else fails take the amp to a local stereo shop and have it tested. Also let me know if you are in the market for a good sub amp. I have a quality one that fits under the seat well and will fully power the 10 you are using. Hope this helps.
Old Feb 3, 2010, 08:19 PM
BoostWhore's Avatar
If you have a multi meter check the ohms on the voice coil. Remove the sub from the box see if it smells burnt and it should be labeled what the voice coil(s) should read while not connected to the amp.
Otherwise somethings wrong with the amp
Old Feb 3, 2010, 08:23 PM
High_PSI's Avatar
Right before this happened I attempted to hook up a cap, would this cause it to happen?
Old Feb 3, 2010, 08:39 PM
jayiszraw's Avatar
did you succesfully hook it up? caps are like sponges they prevent your car audio from being as loud as they should be. they are useless you're better off getting another battery.
Old Feb 3, 2010, 08:47 PM
High_PSI's Avatar
Yeah it sounded like it always did after I got the cap on. Then I got into my car to test the light to see if it would flash when the bass hit and then all of a sudden my bass got VERY quiet. I disconnected the CAP and the bass was just as quiet. I have the gain as far up as it will go and the HZ setting all the way up and it is barely audible. Before it thumped the **** out of my car, now it is like maybe I hear bass, maybe?
Old Feb 4, 2010, 12:45 PM
FJF
FJF's Avatar
Check your ground.
Old Feb 4, 2010, 12:47 PM
Dube's Avatar
If it's not grounded right you probably shorted it. Bye bye sub.
Old Feb 4, 2010, 12:54 PM
FJF
FJF's Avatar
Or, it could just be a loose wire. Never know until it's checked.
Old Feb 4, 2010, 01:57 PM
High_PSI's Avatar
It wasn't the AMP, that's for sure as I tested a brand new one today. The "Accessory" noise is more prominent.
I had the gain turned all the way up just to hear a faint bass sound. If I used my cigarette light, when I push it in it pops. When I hit the breaks I get a weird sound, turn signals and so on.
I hope it isn't the sub, that would be so bad
Old Feb 4, 2010, 02:02 PM
Masdog's Avatar
Same kinda thing happened to me, But I found a better ground and it worked out. But recently since its been really cold it takes a while for the bass to hit full potential. Like if it has to warm up. very weird.
Old Feb 5, 2010, 09:24 AM
BoostWhore's Avatar
sounds like a ground issue... What type of radio do you have pioneers are horrible with noise in their outputs. You can ground the outside of one of the rcas it should help with your engine noise
Old Feb 5, 2010, 10:29 PM
High_PSI's Avatar
Just started working again, no idea why....
Old Feb 5, 2010, 11:00 PM
Rocky2's Avatar
Yea def sounds like a ground issue to me...
Old Feb 6, 2010, 08:45 AM
DannyGSX's Avatar
yeah just loose wiring
Quick Reply: My Subwoofer all of a sudden just got very quiet????
