red line oil for transfer case
Old Dec 23, 2009, 12:16 AM
saad601's Avatar
hey guys,
Could you guys tell me that if i can use the RED LINE MT90 75W90 GEAR oil for my transfer case oil? because right now i cannot get my hands on OEM transfer case oil or any other kind of transfer case oil.
PLease help!
Old Dec 23, 2009, 12:40 AM
GST Motorsports's Avatar
I would use Redline Shockproof Heavy for Tcase. Been using it in my personal evo 8 for 67k miles with a billion track days. Used it my many DSM's before the Evo as well.
Redline MT90 for the 5spd and Redline 75w90 for the rear diff
- Bryan
Old Dec 23, 2009, 12:54 AM
tim85851's Avatar
i went through all of this already...searched plenty of threads...id stick with the factory diaqueen for both transfercase and rear diff...the tranny i rocked some amsoil...
Old Dec 23, 2009, 01:00 AM
JohnDoe1984's Avatar
Amsoil severe gear 75-90 GL5 in the tcase& rear end. I hear that redline has a wax that can accumulate and cause problems.
Old Dec 23, 2009, 01:22 AM
saad601's Avatar
the problem is, we only have red line available here at the moment and not even the OEM fluids are not available...the only option i have is RED LINE ..Which RED LINE product should i go for? for my transfer case
Old Dec 23, 2009, 08:49 AM
Kracka's Avatar
MT-90 is a GL-4, you want to use a GL-5 in the transfer case such as Redline 75W-90 GL-5.
http://www.redlineoil.com/product.aspx?pid=133&pcid=4
Old Dec 23, 2009, 09:12 AM
Gary@MellonRacing's Avatar
3 qts of mt90 for the tranny ( team rip advice )
1 qt diaqueen for transfer
1qt of diaqueen for diferential
just my 2 cents ...
Old Dec 23, 2009, 09:17 AM
evolution2186's Avatar
* 2qt - Redline MT-90 (transmission)
* 1qt - Redline MTL (transmission)
* 2qt - Redline 75W-90 GL-5 gear oil (transfer case and rear differential)
I've been using this routine for 2+ yrs with success!
Old Dec 23, 2009, 09:32 AM
ROGERV's Avatar
- Bryan
+1
40K miles and no problems.
Old Dec 23, 2009, 10:00 AM
Erik@MIL.SPEC's Avatar
I am with GST. Heavyweight Shockproof in the TC and Redline 75W-90 in the rear diff. I have 115,000 miles on my Evo so far. I don't beat on it like Bryan does though
The Super DiaQueen sucked enough that I have been using Castrol Syntorq LT in my 6 speed tranny since 12,000 miles.
That being said, there are plenty of fluids that will work. I didn't like the metal content of my TC oil which is why I switched to the Redline Heavyweight early on.
Old Dec 23, 2009, 10:05 AM
Just pop a quart of Olive Oil in thur. jk
Old Dec 24, 2009, 07:37 AM
Nasty Evolution's Avatar
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOOOOOOOOO.
Use Diaqueen LSD Gear Oil in the TC. Go to the dealer or order it.
Old Dec 24, 2009, 08:03 AM
awdboosted's Avatar
You can use shockproof in the t-case but you must use Diaqueen in the Rear.. If you use Shockproof in the rear the clutch plates will not work properly. In the Trans I use Motul .
I personal use shockproof in my t-case; in hopes to keep the t-case safe and reduce heat build up.
Old Dec 24, 2009, 09:31 AM
It is quite safe to use Redline Heavyweight Shockproof in the TC. The only caveat is it's quite viscous, so if you like changing fluids a lot it will be a PITA to get out.
It is also fine to use Redline 75W-90 gear oil in the rear diff. The clutch packs will work fine.
roblee8908
Nov 3, 2013 08:44 PM
EVOWRC111
Apr 17, 2012 01:46 PM
Babs
14
Sep 16, 2011 02:14 PM
rd122481
Sep 1, 2009 10:38 PM
mitsu IX
11
Apr 10, 2007 06:58 AM
Quick Reply: red line oil for transfer case
