clicking noise under hood when car turned off
Old Oct 19, 2009, 08:50 AM
TrackDays's Avatar
the same clicking noise that happens when you turn the ignition to the on position without starting the car. fuel pump or something? anyways, it has now started happening when i shut my car off after driving for awhile. it doesnt happen everytime, it has happened 2 times out of the last 5 drives. it doesnt just do the clicking noise once like when you turn the car on, it will do it every 3 secs for about 20-30 times. anyone run into this yet??
Old Oct 20, 2009, 08:22 PM
iamblue03's Avatar
that is the timing belt, don't worry about it. it is normal
Old Oct 20, 2009, 08:42 PM
SpeedI2acerX's Avatar
turn signal? but seriously there should be no sound when you turn off the car(fan is ok). maybe the sound of oil dripping down into the pan. the sound before you turn it on is ok.
Old Oct 20, 2009, 08:50 PM
TrackDays's Avatar
its not the signal and its not oil dripping. Every evo x makes the noise when you turn your key to "ON" on the ignition (without turning the car over and actually starting it) its a click click click noise.
Old Oct 20, 2009, 09:05 PM
EricJ@AMS's Avatar
I thought that was an SST thing. My Ralliart does it too.
Old Oct 20, 2009, 09:29 PM
Bighec's Avatar
My GSR does it, it's relays opening and closing I fink. 100% normal...
OT: AMS whats the deal with exhaust mani? Yay, or nay?
Old Oct 20, 2009, 09:36 PM
EricJ@AMS's Avatar
The Evo X turbo kit will happen. Some serious delays with casting, these things happen on occasion.
Old Oct 20, 2009, 11:13 PM
Bighec's Avatar
Koo...
Old Oct 21, 2009, 04:47 AM
aftershock141's Avatar
That is the throttle body. You're fine.
Old Oct 21, 2009, 09:23 PM
EricJ@AMS's Avatar
Today I started a 5 speed X and listened to the sounds you guys are talking about. Definitely not what I am hearing with the SST.
Old Oct 22, 2009, 08:34 AM
TrackDays's Avatar
yeah at least now you know which sound im talking about The only thing that concerned me is after shutting off the car after driving, it would keep doing that click click click on and off for about 20 times before it would finally stop. It has only done it a few times now. Is that normal?
Old Oct 22, 2009, 12:08 PM
K.Bullet's Avatar
Could it be the cat cooling down?
Old Oct 22, 2009, 06:09 PM
nefarious_Saint's Avatar
Dude, dont the evo 10s have a timing chain?
Old Oct 22, 2009, 06:17 PM
macPSU's Avatar
Indeed they do.
Old Oct 22, 2009, 06:21 PM
imboostinnow's Avatar
yes timing chain no belt . you need to let the car sit at idel for a couple( 20 ) seconds before turning it off especially after a hard drive
Ralliart-D
Mar 21, 2016 10:13 PM
Chephevo08
Sep 26, 2013 01:17 PM
lilmac789
Lancer Engine Management / Tuning Forums
Jan 20, 2011 09:56 PM
Braydo25
Lancer Engine Tech
Jun 14, 2010 07:29 AM
GuamLancer
14
Jan 30, 2008 01:42 PM
Quick Reply: clicking noise under hood when car turned off
