how to reset the mileage counter for service inspection
Old Oct 4, 2009, 08:07 PM
dyck888's Avatar
does anyone knows how to reset the mileage counter for periodic inspection back to 5000mi? i did my oil change today and i still have 900 miles left on the counter. i tried to reset it but the screen shows 5900mi/7months. i dont know if i did something wrong or its just ok?
Old Oct 4, 2009, 09:00 PM
Magnus82's Avatar
when the dealer reset mine, it said next service in 10000 miles.... so I dunno if that's normal or not.
Actually that makes sense, I had my oil changed at 5K and next inspection would be for the 15K service. Goofy.
Old Oct 4, 2009, 09:19 PM
08Lancer89's Avatar
I belive it's this while in park and the car in assc mode on the ignition press and hold the info button go to the service reminder. Hold the button for 5-8 secounds until it blinks dashed lines. Then press it again. Should reset. I belive I might be wrongbut I think that's how I did mine.
Old Oct 5, 2009, 07:03 AM
boondoc's Avatar
Yea its the same like resetting the miles on the Odometer
Old Oct 15, 2009, 08:35 PM
20si06's Avatar
Don't have the manual infront of me, but I assume it tells you in there.
Old Oct 16, 2009, 01:40 PM
jkennedy293's Avatar
I did it after my oil change and it only adds 5000 to the mileage. I had drive around for week with the maintenance reminder light on, and when I reset it subtracted that additional mileage from the 5000, making my next oil change due at 4750 miles. I tried resetting again and now it reads 9750 miles. Its a crappy system. The manual says the dealer can reset the interval to anything you want.
Old Jan 4, 2010, 09:20 PM
Chops's Avatar
in canada, they recommend oil changes every 5000 kms...you guys are doing 5000 miles?
Old Jan 5, 2010, 06:43 AM
Psycho09RA's Avatar
I usually change my oil every 3000-4500 miles regardless of if it's Synthetic or not.
Old Jan 8, 2010, 07:59 PM
05SubTecInt's Avatar
Lightbulb Service Reminder - Everything you ever needed to know !!!
Guys/Gals,
This is posted over on MitsubishiForum.com where I am a member.
It is for the Outlander, (which I own), but I think it would also work
on the Lancer as well.
I deactivated mine completely.
Hope this helps !!!
Russ
Some useful info fromthe service manual - here is how to reset your Service Reminder, Change the Maintenance Schedule (factory default is 6 months/7,500 miles but those of us requiring the "Severe Maintenance" schedule can change it as outlined below), or inactivate it altogether:
HOW TO CANCEL THE SERVICE REMINDER WARNING
1. Turn the ignition switch to the "OFF" position.
2. By operating the meter information switch, the warning period is displayed on the multi information display.
3. Press the meter information switch once for 1.2 seconds or longer.
4. The service reminder indicator flashes.
5. While the service reminder indicator flashes, press the meter information switch once for less than 1.2 seconds.
6. The service reminder indicator is turned ON, and "CLEAR" is displayed on the multi-information display for 3 seconds.
7. After "CLEAR" is displayed for 3 seconds, the warning period to the next time is displayed.
HOW TO SET THE SCHEDULE
5. While the service reminder indicator flashes, press the meter information switch 3 times consecutively for 1.2 seconds or longer.
6. The service reminder indicator is turned ON, and the current schedule is displayed on the multi information display.
7. While the current schedule is displayed, press the meter information switch 3 times consecutively for less than 1.2 seconds.
8. The multi information display is shifted to the schedule selection mode.
9. When the meter information switch is pressed for less than 1.2 seconds, the schedule is shifted, and when the switch is pressed for 1.2 seconds or longer, the displayed schedule is set.
10. The schedule set in Step 9 is displayed for 3 seconds, and the warning period to the next time is displayed.
ScheduleWarning types Warning criteria
NAS 10 (initial setting) Elapsed time (month) Every 6 elapsed months
Driving distance (miles) Every 7,500 miles of driving distance
Driving distance (km) Every 12,000 km of driving distance
NAS 11 Elapsed time (month) Every 3 elapsed months
Driving distance (miles)Every 3,750 miles of driving distance
Driving distance (km) Every 6,000 km of driving distance
NAS 20 Elapsed time (month) Every 5 elapsed months
Driving distance (miles) Every 5,000 miles of driving distance
Driving distance (km) Every 8,000 km of driving distance
NAS 21 Elapsed time (month) Every 4 elapsed months
Driving distance (miles) Every 3,750 miles of driving distance
HOW TO INACTIVATE THE SERVICE REMINDER
FUNCTION
By setting to "OFF Display" or "Function OFF" when the schedule is set, the service reminder function can be inactivated.
When "OFF Display" is selected
_ Even when the check warning period is reached, the service reminder display is not displayed.
_ Even if the service reminder screen is displayed by the meter information switch
operation, "OFF" is displayed.
When "Function OFF" is selected
_ Even with the meter information switch operation, the service reminder screen is not displayed.
Old Jan 8, 2010, 08:10 PM
Guys/Gals,
This is posted over on MitsubishiForum where I am a member.
It applies to the Outlander(which I currently own), but I think it
might work for the Lancer as well.
Give it a try. Good Luck !!!
Russ
FUNCTION
Old Feb 13, 2011, 07:55 AM
ErichCS's Avatar
Great info that helped me a lot!
Old May 27, 2011, 03:19 PM
quaggo's Avatar
Yes!! Thanks now I can use this myself, handy for tracking when I need to change my oil.
Old Jul 18, 2011, 08:39 PM
BeyondLimitsEvo's Avatar
Thanks! Big help!
Old Jul 19, 2011, 11:15 AM
total0wnage's Avatar
i think the original owner of my car had the service reminders off cause i have yet to get any and ive driven about 18k.
Old Dec 29, 2012, 09:17 AM
Steven_Trujillo's Avatar
Ok so I just my oil change but the amount of months doesn't change! It's anoying to see I have 18 months to change my oil. Can anyone help me out?
Quick Reply: how to reset the mileage counter for service inspection
