HELP! Air in ABS Unit, how to bleed??
Old Sep 20, 2009, 08:58 PM
8UpUrV8's Avatar
The car has been down without the front brakes on, and pretty sure the ABS has air in it.
I completely bled all 4 wheels, with a vacuum bleeder, for about 30 minutes, went through almost 3 qts of brake fluid-
1st pump- Brake pedal drops straight to the floor, then after pumping it 3 times it gets stiff.
The only soultion i've found so far is going to the stealership so they can activate the abs with a scan tool and re-bleed the brakes...
-Devin
Old Sep 21, 2009, 08:05 AM
griceiv's Avatar
you don't need to bleed the abs. Just bleed the brakes correctly and you'll be fine. Sounds like you're not bleeding both sides of the calipers.
Old Sep 21, 2009, 11:20 AM
8UpUrV8's Avatar
I forgot to mention that the front brake lines have been off for 8 months. The entire system had massive air, and after searching- when the abs unit gets air in it from a prolonged opening in the system, it's a real pain to get it out. Thanks though, i'll bleed them some more.
Old Sep 21, 2009, 01:02 PM
rawkus's Avatar
Consider this http://www.motiveproducts.com/
I have used it with great success on many different vehicles. No issues with air being stuck in the system. Just ensure you have a tight fit on the reservoir to not have any air leaks.
Dan
Old Sep 21, 2009, 01:42 PM
parts68's Avatar
I use
Phoenix Systems Maxi-Ject PRO
pressurize the system from caliper, forces air thru the ABS into the reservoir.
Old Sep 21, 2009, 04:18 PM
8UpUrV8's Avatar
Went through another 2qts of brake fluid, bleeding all 4 wheels- twice more.
Still takes 3 pumps before it starts to get stiff....
Old Sep 21, 2009, 05:38 PM
cfdfireman1's Avatar
evoscan can activate the abs for you, but you'll need a cable and to purchase the program. maybe someone in your area can help you out on this one.
http://www.limitless.co.nz/
Old Sep 22, 2009, 11:32 AM
8UpUrV8's Avatar
Anyone else? I'm trying to source a cable but I really need this done today...
Anyone know if the dealer has the scan tool for this??
vipevo9
Aug 25, 2016 12:36 PM
Montu
18
Apr 22, 2011 05:39 AM
apex electric
Dec 25, 2010 08:46 AM
Mysta Joe
Sep 18, 2010 04:38 PM
aguita
Aug 18, 2009 10:40 AM
Quick Reply: HELP! Air in ABS Unit, how to bleed??
