Autolite Iridium XP Plugs installed- Problem
Old Sep 1, 2009, 09:58 PM
RSGuy's Avatar
Hello,
I just put these plugs in and the car runs but once I get into any kind of boost or throttle, the motor just sputters. I know something is wrong and it is most likely the plugs. I usually run NGK's which have always worked great but Autozone didn't have them. The salesman said that they would be better than the NGK's. Like a fool I decided to get them. Anybody else have a problem with these plugs?
Old Sep 1, 2009, 10:20 PM
epson1's Avatar
check the gap
Old Sep 1, 2009, 10:24 PM
Darwinian's Avatar
What do you have the gap set at?
Old Sep 1, 2009, 10:30 PM
RSGuy's Avatar
I'm not sure what the gap is- whatever gap they come with. The salesman said not to mess with the gap and I read on here that the Autolites should not be re-gapped. I don't know if there is any truth to that.
Old Sep 1, 2009, 10:40 PM
Darwinian's Avatar
Does the salesman own an Evo? I would check the gaps. I just installed NGKs on my car, and its fine. I gapped them to .028, and I have had no problems.
dcpatters's Avatar
Definitely check the gap. How much boost are you running or when does the mis-firing occur?
Old Sep 1, 2009, 11:20 PM
epson1's Avatar
the salesmen is a retard. Get a gap tool and gap them down to .25-.27 depending on your power.
Old Sep 2, 2009, 03:37 AM
tweaker41's Avatar
Check the gap. Your probably getting misfires. The denso ikh24 iridiums come gapped at .032 and you have to gap them down. These are probably the same. When you gap them just tap them on something hard and use a feeler gauge to measure the gap. Don't use the round gapper because you should try to not touch the iridium tip on the plug.
Old Sep 2, 2009, 06:04 AM
Silver Sponsor
Tallen's Avatar
I suggest you listen carefully to this info! Beat me to it...
__________________
-Matt
http://www.SpoolinUp.com
Affordable COP Kits - Back in Stock!
"Performance without the Price Tag"
Old Sep 2, 2009, 07:55 AM
andrewzaragoza's Avatar
if you have an evo 9 it should be .020-.024
Emperor 4g63
16
Jun 8, 2017 12:50 PM
DONNOD
Sep 28, 2016 06:32 PM
Deanooo
Aug 25, 2016 05:17 AM
turbodreamz21
29
Mar 12, 2012 06:51 AM
oldevodude
E85 / Ethanol
34
Apr 14, 2010 07:46 AM
Quick Reply: Autolite Iridium XP Plugs installed- Problem
