How do you recharge the AC?
Old Aug 8, 2009, 06:53 AM
Brent kuz's Avatar
My AC is getting pretty weak just wondering if anyone has a tutorial on how to recharge it using the R13a cans from Autozone. It looks pretty straight forward but just wondering.
Old Aug 8, 2009, 07:52 AM
cfdfireman1's Avatar
per the manual.
REFRIGERANT LEVEL TEST M1552008400312
Use the refrigerant recovery station to remove all of the refrigerant,
and then calculate the amount of the refrigerant and
charge it.
Old Aug 8, 2009, 08:42 AM
NWM_Tech's Avatar
with a machine you recover the coolant that's in the system and then vacuum to boil out any moisture, then charge to an exact amount.
that way you know how much is in the system because too much is just as bad as not enough. If there's some in there you don't know how much to add to get the correct amount.
the 2003 VIII capacity is 18 oz. of R134. (there should be a sticker under the hood somewhere)
With cans you might be able to drain everything out that's in there by pushing down the schrader valve. And then add the correct amount.
Look the system over for oil leaks, like a big dirty patch on the condenser, if there's big oil leaks or if there's very little or no pressure when you push the schrader you have a big leak that should be fixed first before adding R134.
the system contains oil to lube the compressor. It leaks out when you have a big r134 leak. If a large amount leaks out or if you change a component you need to add some oil .
Old Aug 17, 2012, 02:38 PM
EvO8_BT's Avatar
what kind of oil would we need to put in the system
lanport
24
Jun 20, 2015 06:03 PM
adcgn45
Sep 23, 2012 07:25 PM
idriveanevo
Aug 4, 2012 12:31 PM
ohEVO18
Aug 20, 2010 07:32 AM
rcheung
May 27, 2005 07:53 PM
Quick Reply: How do you recharge the AC?
