Squishy brakes/ air noise
Old Jul 24, 2009, 10:47 PM
laksman91's Avatar
I am looking to see if anyone else has this problem. I notice that the first inch or so that I push the brakes it feels very mushy and squishy and not very effective. In addition in this section there is an air-y noise when the brakes are applied. FYI 9200km never raced
Old Jul 25, 2009, 12:53 AM
rams3234's Avatar
Hmm my Ralliart brakes work perfectly, always thought they were the best brakes I've ever had so far. Maybe it's time to change them?
Old Jul 25, 2009, 08:09 AM
justin81's Avatar
I get the same feeling from my brakes. Honestly I think it's a Mitsu thing. My '04 ralliart, my '07 endeavor, and my mom's '08 outlander all have the same squishy weak brakes.
Old Jul 25, 2009, 12:21 PM
Tommy Di Cat's Avatar
My 2001 Galant was that way too. That is until I upgraded to ss lines and higher DOT fluid. I don't know if that would help us though.
Old Jul 27, 2009, 01:41 PM
toredefine's Avatar
Yeah, my '03 OZ Lancer had the same characteristics as you described in the OP.
Old Jul 31, 2009, 07:20 PM
higgs's Avatar
if you listen under the car does it sound like its coming from the master cylinder? Chances are if you are hearing a air noise you have air in the brake lines. I would bleed them asap
Old Jul 31, 2009, 07:47 PM
EvoM Administrator
otter's Avatar
You're not going to hear sound from having air in your brake lines.
The sound your hearing is air being pushed out of the brake booster, which is vacuum powered. That first inch is the amount of pedal travel it takes to start pushing the pads against the rotors. More aggressive pads and SS lines will make the pedal feel more responsive.
Old Jul 31, 2009, 08:08 PM
higgs's Avatar
oh, seemed to fix prob on my last car... if it does have to do with the brake booster valve that is one of the possible known manufacturer defects for 08+ RA next to the hood release cable
Old Aug 3, 2009, 11:56 AM
laksman91's Avatar
I talked to the tech while getting my oil changed. He also said it was the brake booster. I haven't changed that thing yet because they were out of stock. Could be it... Kinda annoying thought
Old Aug 3, 2009, 11:57 AM
laksman91's Avatar
whitenblue65
17
Aug 12, 2009 12:55 AM
Positron
Dec 31, 2008 06:27 PM
RyanShanley
Lancer Tranny/Drivetrain Tech
36
Dec 27, 2004 10:52 PM
GREDDY
28
Dec 2, 2004 08:00 PM
Quick Reply: Squishy brakes/ air noise
