How to tighten gas pedal?
Old Jul 24, 2009, 03:51 PM
btownsoccer22's Avatar
My gas pedal has some free play in it and feels a little loose. I drove my friends evo today, it has no freeplay and feels a ton firmer. Just wondering how to adjust/ tighten thanks
Old Jul 24, 2009, 04:01 PM
dmoevo's Avatar
adjust the throttle cable on the intake manifold but dont tighten too much cause then it will raise your idle
Old Jul 24, 2009, 06:12 PM
cedes14bamg's Avatar
does it do any other side effects beside raising the idle?
Old Jul 24, 2009, 10:31 PM
McLaren F1 2003's Avatar
if you adjust it right...no, it shouldnt have any other side effects
Old Jul 25, 2009, 12:44 AM
Spinitch's Avatar
Just adjust it until there is little to no slack on the cable. You'll notice if it's too tight when your idling higher.
Old Jul 25, 2009, 12:45 AM
Evostacio's Avatar
pics of this cable
Old Jul 25, 2009, 01:23 AM
abdizzle's Avatar
Open your hood. Look down, it's right in your face wrapped around the valve cover ending at the top of the intake manifold slightly toward the throttle body.
Old Jul 25, 2009, 09:46 AM
thanks
but that should help on take offs right?
i wonder if it gives you more hp
Old Jul 25, 2009, 10:35 AM
no it will not give you more hp........how could it?
it will make the response slightly better
Old Jul 25, 2009, 12:11 PM
Evostacio's Avatar
ohhh that cable got itttttttt chieffffff
Old Jul 25, 2009, 12:50 PM
mini_evo's Avatar
I dont want to be the azzhole here.... but i am going to be. HOW the heck can you ask for help and NOT know what people are talking about?!?! I mean really?! Atleast have a clue what you are doing before you go asking for help
Old Jul 26, 2009, 11:38 AM
well that happens when youre a newbie and wonder if your friends tell the truth lol!
Old Jul 26, 2009, 12:52 PM
barneyb's Avatar
A assume you found the slotted bracket. You need to leave a little bit of free play because the cable changes length with temperature. Next winter you may have a high idle if you don't.
Old Jul 26, 2009, 06:34 PM
aschold's Avatar
Originally Posted by cedes14bamg
thanks
Why on earth would it give you more horsepower? Lets use some common sense man.
Old Jul 26, 2009, 06:45 PM
barneyb's Avatar
Lightbulb
If the cable has enough slack in it that the throttle plate isn't opening completely before the WHEEEE pedal hits the stop, adjusting might provide more horsepower.
Quick Reply: How to tighten gas pedal?
