Weird clicking noise when i press gas pedal
Old Jun 30, 2009, 02:09 PM
C_LosEvo's Avatar
While driving every time i press on the gas pedal i hear a "click click" and goes away. The noise is coming from the front under driver side. I lifted the car and looked to see if the drive shaft is touching anything but it seems fine. any guesses?
JeyEvo (Jun 14, 2016)
Old Jul 1, 2009, 10:16 PM
linuxbatm's Avatar
Could it be a relay switching?
Old Jul 2, 2009, 07:46 PM
Lessor's Avatar
i dont know it you have done any exhaust work or taken the the lower bars that goes across the exhaust. forgot what there called. but check the chrome spacers that go in between the bar and the frame to create a gap so the downpipe isnt hitting the small black bar.
i stuck the spacer on backwards and when i would hit the gas the downpipe would make a tapping noise on that bar.
Old Jul 2, 2009, 07:56 PM
Registered User
Cali2MDevo8's Avatar
My clutch pedal makes that little squeak noise. Not the gas pedal though.
Old Jul 4, 2009, 06:26 AM
EVO8emUp's Avatar
It should be doing it around 0-1psi. I believe it's the fuel pump relay.
Old Jul 4, 2009, 06:43 AM
fqjdmct9a's Avatar
i been having the same problem lately i just hear a "click"
Old Jul 4, 2009, 06:55 AM
WRC-LVR's Avatar
gm 3 port solenoids make this sound. Fair number of people have made the comment. Mine does it.
Hope this helps
milburn
Old Jul 4, 2009, 07:25 AM
fqjdmct9a's Avatar
Old Jul 5, 2009, 03:56 PM
elijahcole92's Avatar
wierd exhaust leak??!?!
Old May 4, 2011, 04:08 AM
IS2000's Avatar
Bumping up this old thread,
Recently I also noticed every time I pressed the gas pedal (about 10-15% in) there's a clicking sound coming from the pedals area. It only does this when the car is moving both in gears and in neutral. Any idea what causes this?
Old Oct 28, 2011, 08:57 AM
pltek's Avatar
me too, it seems like its coming from behind the hvac controls, it has to be a relay?
CarPhoto.net
22
Jun 27, 2016 06:58 PM
LovingLancer
Lancer Troubleshooting
Mar 29, 2014 03:03 AM
sette3
Jul 6, 2007 04:11 AM
k270kmh
30
Aug 13, 2006 05:19 PM
Quick Reply: Weird clicking noise when i press gas pedal
