no spark check list.. help!!
Old May 12, 2009, 12:32 PM
yellowevo82's Avatar
still not getting any spark in the evo from my build, im tired and im running out of options or mind power.. can someone please type me up a checklist for reasons why i would not get spark.. ( i have power to the battery just no spark)
Old May 12, 2009, 12:34 PM
biggie5252's Avatar
Are you getting fuel?
Old May 12, 2009, 12:48 PM
yes i took off the fuel feed line and it was gushing out..
Old May 12, 2009, 01:19 PM
anybody?
Old May 12, 2009, 01:37 PM
crank sensor and cam sensor are new, i have fuel..
Old May 12, 2009, 06:42 PM
Adam@MMS's Avatar
Either the ECU is telling the coil to fire or it isn't. If it isn't then something is wrong with the cam or crank sensor input, I don't think it could be anything else, at least I can't think of anything else sensor wise. Pull up a wiring diagram or two on AllData maybe. I assume you checked fuses. If the immobilizer code in the ECU isn't right it will not fire. That's all I got. Better than nothing.
Old May 12, 2009, 11:17 PM
im running an ems and i have pulled the wiring diagram
Old May 14, 2009, 02:55 PM
biggie5252's Avatar
Are the injectors firing?
Old May 14, 2009, 03:08 PM
took the spark plug out grounded it and im getting no spark.. spark plugs smell of gas so i assume yes there firing.
Old May 14, 2009, 07:21 PM
barneyb's Avatar
I had this problem once with my DSM. So I put the charger on the battery for 15 minutes and all was fine.
Old May 14, 2009, 07:43 PM
Registered User
rolly1818's Avatar
i think ur batter is messed up......
i know ur gonna say no but check it lol....
Old May 14, 2009, 11:39 PM
i jumped the car for 10 min
Old May 15, 2009, 01:54 PM
still cant figure it out...
Old May 15, 2009, 02:37 PM
ecu is coming on , just still no spark..
Old May 16, 2009, 01:03 AM
Registered User
rolly1818's Avatar
did u try a new battery? did u check all the fuses (i am not familiar with AEM system).
Quick Reply: no spark check list.. help!!
