E85 / Ethanol This section is dedicated to tuning with ethanol.
show pics of flex fuel sensor mounting location
Old Apr 6, 2009, 06:50 AM
mrfred's Avatar
I'll be installing my GM flex fuel sensor this week and am trying to decide a good place to mount it. If you have some time, please post a pic showing the location where your GM flex fuel sensor is mounted. Thanks.
Old Apr 6, 2009, 09:30 AM
skiracer's Avatar
I have mine zip tied to the strut bar, right in front of the brake fluid resevoir. I also have the "tubes" pointed downwards. I'm out of town now but i can take pics when i'm back home.
Old Apr 6, 2009, 09:43 AM
mrfred's Avatar
Do you see much variation in the ethanol content gauge when you go WOT?
Old Apr 6, 2009, 01:06 PM
skiracer's Avatar
No variance in ethanol % at WOT for me. The only thing that variates a little is the fuel temperature..
Old Apr 6, 2009, 04:32 PM
skiracer's Avatar
sensor zip tied to the OEM strut bar. Fuel tubes are facing downwards Note, I put a black wristband around the sensor to keep the popo at bay. Its a pain to remove the wristband, so i pushed away as much as i could.
Closer view
View of the flex fuel sensor wiring harness facing the passenger side of the car
Old Apr 6, 2009, 09:08 PM
skiracer's Avatar
pic of the sensor in case others whom are reading this have no clue what the flex fuel sensor looks like
Old Apr 20, 2009, 08:49 PM
skiracer's Avatar
Did you ever install the flex fuel sensor yet?
Old Apr 20, 2009, 09:34 PM
mrfred's Avatar
I'll be installing it next week. :-) Still haven't decided where I'll mount it. I'm hoping that once I place the sensor in the engine bay, a good location will become apparent.
Old Apr 21, 2009, 06:21 PM
merkzu's Avatar
I have mine in the same spot
Old Apr 21, 2009, 08:41 PM
skiracer's Avatar
Did you use zip ties to attach it to the strut bar or you make some sort of a bracket?
Old Apr 22, 2009, 08:25 AM
merkzu's Avatar
Mine's just zip tied like yours. Would be cool if someone could fab some brackets though =)
Old Apr 22, 2009, 08:27 AM
merkzu's Avatar
My ethanol % reading drops a bit at WOT, I've always just assumed it was because there wasn't enough fuel in the return line to get a good reading.. not sure
Old Apr 22, 2009, 08:42 AM
Zeitronix's Avatar
The FF sensors needs to be full of fuel or the readings are unstable. We have seen a drop by 1% at WOT, but with big injectors and fuel pump working 30% harder you may see a higher drop. What numbers are you seeing
Old Apr 22, 2009, 08:46 AM
redevo58's Avatar
What is the purpose of this sensor?
Old Apr 22, 2009, 09:04 AM
Zeitronix's Avatar
Tells you how much E is in your E85
http://zeitronix.com/Products/ECA/ECA.htm
Quick Reply: show pics of flex fuel sensor mounting location
