bubbles in oil on dipstick?
Old Mar 15, 2009, 12:22 PM
cosworthevo1133's Avatar
yesterday my car was running fine, then last night i started overboosting to over 30psi to where my car was shaking back and forth, i checked all the vacuum lines and put one back on but my question is why are there tiny little air bubbles on my dipstick in the oil? i mean i dnt know if it even means anything but if you guys have any advice please give me some input... im tuned currently for 24psi on 93 oct.. have a fp white turbo, injen intake with upicp/licp, dp,tp, cossie 272s with cosworth head internals, carbon ti exhaust and running ams oil 10w30 also have a balance shaft eliminator kit on a stock shortblock
Old Mar 15, 2009, 12:24 PM
smokedmustang's Avatar
sounds normal to me.
Old Mar 15, 2009, 12:26 PM
well yesterday it didnt have the tiny little bubbles and today when i checked my oil i thad then and i also forgot to mention that i have a small oil leak
Old Mar 15, 2009, 12:29 PM
c kim's Avatar
If theres too much oil in your engine, the oil can foam up and you'll see those bubbles. Thats one idea.
Old Mar 15, 2009, 12:32 PM
ok, will that affect any thing if there was too much oil in it?
Old Mar 15, 2009, 12:35 PM
apagan01's Avatar
its happens when you check your oil right after you turn your car off, when you come back from the road.
very normal
Old Mar 15, 2009, 12:43 PM
ok well i just did another pull down the road, and i thought i fixed all the vacuum lines but it is still over boosting and the oil still has bubbles, but i dnt know where another vacuum line could be loose, its very weird when i floor it, the needle goes smooth through the rpm but the car shakes back and forth like a slipping clutch but when it starts shaking the needle still flows smooth through the rpms...im very confused
Old Mar 15, 2009, 12:46 PM
apagan01's Avatar
-Spark plugs
-bost cut, fuel cut ( which could be the issue because you are over boosting) go and find out why are you over boosting.
- bad gas tank
man the bubles are fine dont wory about them
Old Mar 15, 2009, 12:52 PM
ok... what do u mean by bad gas tank?
Old Mar 15, 2009, 12:53 PM
amui07's Avatar
Yes, having too much oil is bad for the car.
Old Mar 15, 2009, 12:54 PM
apagan01's Avatar
what they sold you is not 93oct. however that wont exlpain the spike
did the spiking just randomly happend or have you changed somthing.
check your waste gate, and its vacume lines
Old Mar 15, 2009, 12:55 PM
ok well too much oil is out of the question because it is 3/4 full on the dip stick reading
Old Mar 15, 2009, 01:03 PM
i havent changed anything at all, i went to sam's yesterday and filled my tank with 93 usually i do other gas stations then sam's...but it just started spinking randomly last night and then again this morning
Old Mar 15, 2009, 01:11 PM
mugen777's Avatar
Check the EGR valve vaccum line, its hard to reach its under the throttle body. Its a very common place to have a boost leak. If you did indeed blow it off I recommend using a zip tie and some hairspray
Also sounds weird, but check your timing as well.
And of course a boost leak test.
Old Mar 15, 2009, 01:16 PM
ok thanks ill check that when my buddy gets here to help me fix it....could there be anything else besides the vacuum lines, bad fuel, or wg
Quick Reply: bubbles in oil on dipstick?
