Need Advice for Timing Belt Replacement
Old Mar 1, 2009, 02:37 PM
evolution mr's Avatar
Question Need Advice for Timing Belt Replacement
I would like to plan on doing a timing belt replacement and advice.
Is there anything else that I should replace when doing the timing belt?
MD352473 Balance Belt Tensioner/Pulley
MR984375 Timing Belt Hydraulic Tensioner
MD369999 Timing Belt Idler Pulley
MD998738 Mitsubishi Timing Tool
I am purchasing the belts from a vendor:
Power Enterprise Super Strong II Balance Belt $48.00
Power Enterprise Super Strong II Timing Belt $158.00
Power Enterprise Super V Accessory Belt $98.00
In addition I plan on replacing the PCV valve
MD152772 PCV valve
MN158072 PCV valve hose
Old Mar 1, 2009, 02:42 PM
I presently have 55K+ mileage
EvolNinja's Avatar
I haven't done mine yet but I would def recommend you doing the water pump too bro. How many miles do you have on your Evo now?
Old Mar 1, 2009, 02:43 PM
EvolNinja's Avatar
My bad... I think we must have post it at the same time about the mileage thing
Old Mar 1, 2009, 02:44 PM
takeshi999's Avatar
definately do the water pump too...
Old Mar 1, 2009, 02:45 PM
Replacing the water pump at 55K+. Is it because since your replacing most of the parts in the area you should do the water pump anyways?
Old Mar 1, 2009, 02:55 PM
EvolNinja's Avatar
Yes because if you don't, it's going to cost you time later on and you're going to feel like kicking your self on the rear end not to do it
Old Mar 22, 2009, 06:10 PM
tomcox58's Avatar
Timing belt
Is the timing belt changed on age or milage? I know our schedule says 5 years or 60 K, but can we go longer safely. Are our engines interference or non-interference engines? Not to change the topic.
Tom
Old Mar 22, 2009, 06:14 PM
Malik_EvoIX's Avatar
o i c
Old Mar 22, 2009, 06:20 PM
Smike's Avatar
Tom
Well if you hit 60k before 5 year - then change it.
I would NOT push past 60k - I have seen them skip and break in other cars.
We have interference motors - they go - so do your pistons, valves, wallet.
Old Mar 22, 2009, 06:38 PM
tomcox58's Avatar
Smike,
Thanks for the quick reply.
Tom
Old Mar 22, 2009, 06:44 PM
Smike's Avatar
Welcome.
Old Mar 22, 2009, 08:16 PM
Registered User
rolly1818's Avatar
switch it, and change the water pump to.
u can go OEM or aftermarket on the water pump and belts.
there is a good write up on Evom if your into the DIY thing
Old Mar 27, 2009, 09:01 AM
3zero7's Avatar
anyone used the PCI timing belt kit sold in Ebay?Is it any good? Its much cheaper than oem. below is a write up in their ebay store.
"This kit is assembled by Preferred Components, using components that meet or exceed OEM specifications. PCI specializes in supplying OHC timing sets & components for the "professional installer". PCI is an importer and supplier of high quality timing system products manufactured by both OEM and aftermarket manufacturers that have OEM business and understand quality standards"
Old Mar 27, 2009, 11:52 AM
Registered User
rolly1818's Avatar
personally i wouldn't a timing belt is one of the most important parts of the Evo.
this is not the parts you go cheap on.
its up to you though you money and ur car. i went OEM tensioners and water pump with greddy belts.
Quick Reply: Need Advice for Timing Belt Replacement
