Evolution X TSB / Recall Information
Old Feb 21, 2009, 07:19 AM
mrMTB's Avatar
Lightbulb Evolution X TSB / Recall Information
Here is a list of the Technical Service Bulletins and Recalls for the 2008 USDM Evolution X...
TSB Number (Issue Date) - TSB Title
08-00-002 (01/08) - X New Model Service Information (techtrain)
08-13-006 (03/08) - ECM REPROGRAMMING FOR DTC P1320 (techtrain)
08-13-006REV (??/08) - ECM REPROGRAMMING FOR DTC P1320 (techtrain)
08-13-006REVII (??/08) - ECM REPROGRAMMING FOR DTC P1320 (techtrain)
08-13-011 (05/08) - Engine Controls - Slight Hesitation When Accelerating (techtrain)
08-21-001 (??/08) - CAUTIONARY INSTRUCTION FOR HANDLING CLUTCH INTERLOCK SWITCHES - SMR (techtrain)
08-31-001 (??/08) - TPMS Sensor Service (techtrain)
08-35-001 (??/08) - Cautionary Instruction for handling Stop Light Switches - SMR (techtrain)
08-42B-003 (05/08) - Body - Revised Welding Points For Fender Shield (techtrain)
08-42A-008 (05/08) - Antenna - Revised Description For DTC B240A/B240B (techtrain)
09-42A-004 (04/09) - Rattle from Doors. Loose Window Bolts - 08-09 Lancer, EVO X, SPORTBACK
08-22-002 (06/08) - A/T - W6DGA Twin Clutch Transmission Characteristics (techtrain?)
08-33-001 (06/08) - Suspension - Revised Control Arm Securing Procedure (techtrain?)
08-42A-008 (??/08) - Corrected procedures for DTCS B240a & B240b - SMR (techtrain)
08-42A-012 (07/08) - Body Controls - DTC B240E Correction (techtrain)
08-42A-013 (07/08) - Keyless Entry/Starting - F.A.S.T. Key Feature Inop. (techtrain?)
08-51-001 (07/08) - Body - Revised Moulding/Garnish Removal/Installation (techtrain?)
08-22-003 (07/08) - Engine Controls - Coding Precaution Manual Revision (techtrain?)
08-52B-002 (07/08) - Alignment procedure for clock spring neutral point - SMR (techtrain?)
Recalls
September 2009 - Fuel Rail (url)
Service Campaigns
April 2009 - Hood Release Cable (url)
September 2009 - AWC Control Unit Reflash (url)
Last edited by mrMTB; Oct 3, 2009 at 06:57 PM. Reason: adding techtrain links - will ask someone with a login to download and attach
Old Feb 21, 2009, 07:20 AM
mrMTB's Avatar
Holding for future use
Old Feb 21, 2009, 07:24 AM
Smike's Avatar
Gov't link to search also:
http://www-odi.nhtsa.dot.gov/recalls/RecallSearch.cfm
Old Feb 22, 2009, 09:26 PM
evoyao's Avatar
So, If I got my EvoX in January 2009, should I have to go back to dealer for revising these issues?
Old Feb 23, 2009, 05:36 AM
tsitalon1's Avatar
User/Pass for techtrain?.....I can ask can't I
Old Feb 23, 2009, 06:24 AM
mrMTB's Avatar
Techtrain is the Mistubishi site for training their people. I put up those links because I asked a friend who works for a local dealership to download those for me when they get a chance. I'll post up links when I get the docs.
Old Feb 25, 2009, 07:59 AM
Smike's Avatar
https://www.evolutionm.net/forums/mi...ml#post6736142
Also a great thread!
Old Feb 25, 2009, 08:06 AM
Plat Vendor
RussellM's Avatar
Here you go sir, per your request -- I think I edited out all the VIII and IX stuff. Should be only CY4A & CZ4A information here.
Fluids & Service Specifications
https://www.evolutionm.net/forums/mi...22-fluids.html
https://www.evolutionm.net/forums/ev...quirments.html
https://www.evolutionm.net/forums/ev...fications.html
TSB's & Recall's
https://www.evolutionm.net/forums/mi...ogramming.html
https://www.evolutionm.net/forums/mi...teristics.html
https://www.evolutionm.net/forums/ev...formation.html
https://www.evolutionm.net/forums/ev...subwoofer.html
https://www.evolutionm.net/forums/mi...cer-evo-x.html
https://www.evolutionm.net/forums/mi...formation.html
https://www.evolutionm.net/forums/ev...e-01-08-a.html
General Information
https://www.evolutionm.net/forums/mi...-materiel.html
https://www.evolutionm.net/forums/mi...ode-guide.html
Technical Information & How-To's
https://www.evolutionm.net/forums/ev...tructions.html
https://www.evolutionm.net/forums/ev...locations.html
https://www.evolutionm.net/forums/mi...end-parts.html
https://www.evolutionm.net/forums/mi...locations.html
https://www.evolutionm.net/forums/ev...id-change.html (Evolution X)
Old Mar 23, 2009, 05:58 AM
crump's Avatar
anyone check there is going to be a recall in april
Old Apr 13, 2009, 03:58 PM
shazad's Avatar
is this for GSR Or MR Or Both?
Old Apr 13, 2009, 08:21 PM
mrMTB's Avatar
Both. Only things I can think of that would affect one or the other would be things impacting the tranny/shifter (08-22-002 is MR specific because it deals with the TC-SST).
Old Apr 16, 2009, 09:14 AM
Webman's Avatar
There are other vehicles with the TC-SST
Old Apr 16, 2009, 06:45 PM
Nismo2GRS's Avatar
What recall are you talking about?
Old Apr 22, 2009, 10:10 AM
EvoX777's Avatar
I just got back from the dealership service manager told me there is a recall for the hood latch wire. Everyone should receive something in the mail.
Old Apr 22, 2009, 10:26 AM
jve153's Avatar
pm me with the last 8 of your vin and I can look you up to see if you are affected.
this recall applies to the 08 evolution and some 09 ralliarts.
Quick Reply: Evolution X TSB / Recall Information
