Best spark plugs for evo 8
Old Feb 9, 2009, 07:23 PM
pcamara17's Avatar
Let me know what spark plug to get and the a link if possible
Old Feb 9, 2009, 07:25 PM
derangedazn's Avatar
Search Spark plugs.
Old Feb 9, 2009, 07:48 PM
pcamara17's Avatar
^ search where?
Old Feb 9, 2009, 08:22 PM
dude's Avatar
NGK BR_ES (7 for stockish, 8 for modded)
Old Feb 9, 2009, 08:25 PM
Adam@MMS's Avatar
stock
Old Feb 9, 2009, 08:45 PM
MasterNater's Avatar
Copper Plugs:
Stock/Bolt-Ons - BPR7ES
Bolt-Ons/Bigger Turbo + High Boost - BPR8ES
Iridium Plugs:
Stock/Bolt-Ons - BPR7EIX
Bolt-Ons/Bigger Turbo + High Boost - BPR8EIX
Link...
http://www.extremepsi.com/store/cust...pe=Spark+Plugs
Copper plugs are cheaper but need to be changed more often. Plugs with the heatrange of 7 should be good for boost levels of 25 and below. If you're running more than that, you should probably go for heatrange 8.
Old Feb 10, 2009, 06:20 AM
gsrboi80's Avatar
Id buy the BR7ES and the BPR7ES. Try them both and decide which you think your car runs better on.
BR7ES - Non Protruding Tip
BPR7ES - Protruding Tip
I used to run the BPR I then tried the BR and found the car to like non protruding a bit more. I wouldn't switch to 8's until you gobigger turbo
The 7's = Stock heat range
The 8's = A step colder
Incase your were confused
Last edited by gsrboi80; Feb 10, 2009 at 06:25 AM. Reason: UUUR proofreading owns me LOL
Old Feb 10, 2009, 06:23 AM
Turbo-Evo2346's Avatar
You can go to NAPA auto parts and get the NGK BPR7ES copper plugs. They are like 2 dollars each and work great.
Old Feb 10, 2009, 09:36 AM
mplspilot's Avatar
I think my BPR's knock less than BR.. it may be subjective... but theory goes that the closer the spark to the center of the chamber (with projected/protruding design) — to ignite the mixture from the center — the better the results/burn. If it's burning from the middle the process should happen faster (good for power and knock prevention). Non-protruding/projected tips were designed for smaller clearance chambers to avoid the piston hitting the plug tip.
It's also thought that BR is a half step colder than BPR..
All above, FWIW...
Oh and this:
Originally Posted by pcamara17
^ search where?
rly?
Old Feb 10, 2009, 11:07 AM
gsrboi80's Avatar
^ Thinking about it that does make a lot of sense. I did run the BPR's for a while like I said though the car seem to run a bit smoother from the BR's. This was on the stock heat range with full boltons.
Now I'm big turbo and switched to the 8's. I immediately just picked up the BR's as I ran them in the 7's.
I'm going to grab BPR8's and see if I can feel any difference good or bad from the BR8's. I'll put the car into various situations and log each (Not sure that I'll see anything).
I def see where the theory of the protruding tip should produce a more complete burn.
Good Discussion
Old Feb 12, 2009, 08:37 PM
pcamara17's Avatar
thanks for the help
Old Feb 13, 2009, 04:05 AM
sparky's Avatar
There is another school of thought which contends that a protruded tip, such as that of the BPR's is more prone to preignite the air/fuel mixture than the BR's recessed tip is. In this scenario, the hot, glowing tip, protruding further down into the combustion chamber, auto-ignites the air/fuel mixture prematurely, before the piston reaches TDC on the compression stroke, and before the sparkplug fires.
Old Feb 13, 2009, 04:47 AM
sparky's Avatar
EDIT: Sorry.
Old Feb 13, 2009, 06:19 AM
Dennis F's Avatar
You can also pick these plugs up at Pep Boys in Raynham or however you spell it. They had them in stock a couple weeks back when I got them.
Old Feb 13, 2009, 06:23 AM
sharkm87's Avatar
ngk bpr7es
.026 gap
Quick Reply: Best spark plugs for evo 8
