starter probs
Old Oct 29, 2008, 07:11 PM
1 WICKED EVO's Avatar
starter probs
i have an evo8. well my car has had some problems starting 4 a while know. at first it was an every now and then problem that my car would just click and not start but it only did it like once a month. well recently it did it every day i would have to jump it off then i could turn the key and it would start. so i went and bought a new starter and batt and it still does it sometimes. it will just click like its a relay or the starter. is there a relay under the hood 4 the starter or anything to do with the ignition?. iam running out of ideas please help
Old Oct 29, 2008, 07:21 PM
steelcityevo8's Avatar
bump for this , I had experienced the same issues !!!!!
Old Oct 29, 2008, 07:27 PM
1d10t's Avatar
check wire to the S- terminal of your starter-may have a break somewhere causing intermittent issues. Make sure all of your connections to the starter are tight as well as the battery terminals.
Old Oct 29, 2008, 07:30 PM
planetboy200's Avatar
its not ur starter its the starter relay that cant give the starter enough juice to crank the starter . I had the same problem so i had to put another relay from the batt to the starter. That fixed the problem
Old Oct 29, 2008, 07:32 PM
1d10t's Avatar
^there ya go.
Old Oct 29, 2008, 08:16 PM
cosworthevo1133's Avatar
ya agree
Old Oct 30, 2008, 01:41 AM
icantdrive75's Avatar
In this instance it's almost always a problem with the grounding wire coming loose or having bad contact with the chasis. Check and make sure that's on a good clean surface before buying any more parts.
Old Oct 30, 2008, 07:39 PM
maybe a stupid quetion but were is the relay located? thanks 4 the help guys
Old Dec 9, 2008, 03:29 PM
TIBOevo's Avatar
hey guy, did you ever figure this out?. cause im going to the samething. did the relay switch work when replaced?.
Old Jan 25, 2009, 08:33 PM
no man i dont know where it is, if someone would tell me ill let u know lol
Old Dec 6, 2009, 01:48 PM
evo9rl's Avatar
bump im having the same issue where is the starter relay located????
Old Jun 28, 2010, 07:52 PM
OmgGG's Avatar
anyone know where theyr relay is?
Old Jun 29, 2010, 12:17 PM
barneyb's Avatar
On my 8 it is in the relay box next to the battery, first row next to the battery at the front.
Don't forget to check the clutch switch, it is also in the circuit.
Old Jun 29, 2010, 02:50 PM
OneEyedJack's Avatar
From my evo 9 fsm. Should be the same on your vehicle.
tsidrift1
Dec 26, 2015 01:49 PM
dbltz
Oct 16, 2015 08:14 AM
Night12000
Sep 28, 2015 08:03 AM
VOridin
Mar 25, 2013 05:15 AM
Quick Reply: starter probs
