Evo 8 Compression Test
Old Aug 23, 2008, 07:47 AM
YNGEVO's Avatar
From left cylindar to right cylander i got
153-160-165-165
I was told that was good for 08 motor with 65k miles..
Old Aug 23, 2008, 07:50 AM
YNGEVO's Avatar
i meen 03 motor.
Old Aug 23, 2008, 07:51 AM
YNGEVO's Avatar
and these numbers i DID NOT open the throttle by pushing all the way on the gas when cranking over. So these numbers prob would be a little higher
Old Aug 23, 2008, 11:17 AM
mojo's Avatar
I just did my 03 with 50k. 175-166-175-176 WOT
Old Aug 23, 2008, 11:22 AM
Smike's Avatar
7. Crank the engine with the throttle valve fully open and
measure the compression pressure.
Standard value (at engine speed of 250 r/min): 1,128
kPa (163 psi)
Minimum limit (at engine speed of 250 r/min): 951 kPa
(138 psi)
8. Measure the compression pressure for all the cylinders, and
check that the pressure differences of the cylinders are
below the limit.
Limit: 98 kPa (14 psi)
9. If there is a cylinder with compression difference or a
compression difference that is outside the limit, pour a small
amount of engine oil through the spark plug hole, and repeat
the operations in steps 6 to 8.
(1) If the compression increases after oil is added, the cause
of the malfunction is a worn or damaged piston ring
and/or cylinder inner surface.
(2) If the compression does not rise after oil is added, the
cause is a burnt or defective valve seat, or pressure is
leaking from the gasket.
Old Aug 23, 2008, 11:28 AM
EVOLVEU's Avatar
compression looks fine
Former Vendor
Curt@MrLed's Avatar
Your in good shape. no worries
Old Aug 23, 2008, 11:31 AM
EVOLVEU's Avatar
I think its 15-20% difference between cylinders that you need to worry.
Old Sep 19, 2008, 10:32 AM
04evony's Avatar
mine is 150 on all of them is that ok
slow5.0.
24
Nov 18, 2010 04:08 AM
jasonrp15
Southeast Region
13
Jun 24, 2008 10:11 AM
ggevoIX
For Sale - Cars For Sale
11
Jun 4, 2008 06:30 PM
jasonrp15
17
Apr 1, 2008 07:38 AM
Lancerzz
25
Mar 12, 2008 11:33 AM
Quick Reply: Evo 8 Compression Test
