View Poll Results: After slipping began. How long did your clutch last before you changed it?
I didn't wait long enough to find out
13
24.07%
500-999 miles
10
18.52%
1000-1999 miles
3.70%
2000-2999 miles
7.41%
3000-4999 miles
3.70%
5000+ miles
23
42.59%
Voters: 54. You may not vote on this poll
How long did your clutch last after it started slipping?
Old Aug 12, 2008, 10:46 PM
klange's Avatar
How long did your stock clutch last after it started slipping?
So my Stock clutch started slipping yesterday...
I was wondering how long it might last if I try not to push it too hard and baby it a little.
I have a stock 03 and it's my daily driver.
Thx.
Last edited by klange; Aug 12, 2008 at 10:53 PM. Reason: To specify it was my stock clutch
Old Aug 12, 2008, 10:53 PM
newimportowner's Avatar
Not long after it started slipping. Baby it. I miss read this the first time around, but I started getting strange things (surging at low RPM) but it got worse fast. start your budget now and get a new one quick.
Old Aug 12, 2008, 10:57 PM
klange's Avatar
Originally Posted by newimportowner
Dont you think you should open this window up a bit. for christs sake i ran 35K with many drag nights in the 12 second marks. this is almost hard to believe the window is so small.
and thinking more, I jsut rolled 52 k total on the odometer, and new clutch is as good as new, but this one should last a lot longer Exedy double HD.
Your clutch lasted 35K AFTER it started slipping??? And you drag raced it???
Old Aug 12, 2008, 11:01 PM
No No Like I said I miss read your original post, thats why I edited it. My bad. Good thing I looked twice sorry for the confusion. it didnt last too long after it started, and I drove i t for about 28-30K before it started. I drive 40K/year so factor that in. My 05 I had lasted 40K w/o slipping but the IX does make a touch more power though too.
Old Aug 12, 2008, 11:07 PM
again I hope you read your PM. I missed a few words in your post. I change oil atleast every 3 weeks cause I do daily drive my car over 40K/year. so it stated slipping and within 4-5k I had to dump it it stunk too. I did beat it pretty hard though.
Old Aug 13, 2008, 12:19 PM
klange's Avatar
No problem.
Wow every 3 weeks? So you spend about $1000 on oil changes each ear!!!
I'm basically trying to get and idea on how long before I absolutely need to change the clutch...
Old Aug 13, 2008, 12:25 PM
DJ Brett B's Avatar
Mine slipped for about 20 miles before it was so bad I could barely move forward- that was following cams/DP/O2/Ported ex. mani/reflash.... too much power for a clutch that had just started slipping and it went down hill fast!!! Replaced with Exedy twin
Old Aug 13, 2008, 12:56 PM
SHIFTT IX MR's Avatar
My clutch could not hold the car on a hill, this occured the same day I purchased the car - brand new, with 6 miles on it. I'm pretty sure the stock EVO clutch is designed to slip straight from the factory (in an effort to protect the drivetrain from inexperienced driver inputs). Got a WORKS stg. II clutch, and couldn't be happier.
Old Aug 13, 2008, 02:29 PM
vwjeff's Avatar
I voted 3 to 5k... but on my Triple with over 100 passes
Old Aug 13, 2008, 03:45 PM
evoPirate's Avatar
When my stocker started slipping I was able to get about 800 more miles out of it really babying the car. Never went over 3200rpm, stayed off the highways. Happened a few days after my e85 switch, it was torture not being able to romp on her. On the other hand I was getting like 28mpg lol
Old Aug 13, 2008, 04:14 PM
turbodreamz21's Avatar
i had a 2003 evo8 with about 22k on the car and clutch was fine tracke dit afew times to atleast 13 times on stock clutch
i had
ams fmic tbe cams all the oblt ons
Old Aug 13, 2008, 06:22 PM
C6C6CH3vo's Avatar
3 clutches thus far. first one lasted 35000 because the first 20k the car had no power. second one lated 10k and 3rd one is still going strong with 4000 miles
Old Aug 13, 2008, 06:51 PM
ace_2822's Avatar
How did you get 28 mpg with e-85? I thought you got worse mpg.
Old Aug 14, 2008, 10:32 PM
klange's Avatar
Hmm, why not use your warranty and get a new stock clutch, beat it to death, then buy the stg. II clutch?
Old Aug 14, 2008, 10:44 PM
EvoHung's Avatar
Mines lasted me a few thousand miles before it completely went out. Started slipping at around 46k miles and clutch gave out completely at 50k. When it started slipping, I did not boost it at all. I was just driving it to work and home.
Quick Reply: How long did your clutch last after it started slipping?
