How to adjust KW Coilovers
Old Jun 12, 2008, 08:14 AM
AlvinHuyN's Avatar
Hey guys,
I bought a set of KW coilovers used so I didn't get the manual for them. How do you adjust the firmness on these. They came to me at almost full stiff and I need to soften them a bit. Thanks
Alvin
Old Jun 12, 2008, 08:36 AM
inco9nito99's Avatar
edit: checked the car:
Full stiff- tightest clockwise.
Rebound on top, Compression on bottom.
Old Jun 12, 2008, 10:25 AM
GTWORX.com's Avatar
^ Clockwise is stiffer.
-drew
Old Jun 12, 2008, 12:37 PM
ustcc evo's Avatar
Besides the specifics to your KWs, a great place to advance your learning on how to adjust shocks is the Koni Motorsports web site and catalog. This catalog has some great tips on exactly how to adjust the shocks and even how to select spring rate.
http://www.koni-na.com/pdfcatalogs/K...ortCatalog.pdf
If you can read and understand this catalog, you will know more than most racers. However, even a beginner can utilize the tips and tricks they offer in order to learn how to do simple adjustments on the shocks and get great results, on and off the track.
Old Jun 12, 2008, 04:18 PM
AlvinHuyN's Avatar
Thanks guys, this is why I love EvoM. Always endless amount of good information and many members are willing to take their time to help others, especially a new comer to the Evo like myself Thanks again!
Old Jun 12, 2008, 07:42 PM
06ssdevo9's Avatar
No pic of the drop?
Old Jun 12, 2008, 11:01 PM
fvaldes's Avatar
I installed a set of KW I purchased from Robispec and the first day the car was solid a rock. The suspension was so firm or I would say stiff that I thought something was wrong. After several hours they began to loosen up and by the next day they were perfect. I think that the gas somehow has to acomodate itself until it is working properly . I don't know, but now my KWs work like a dream!
Old Jun 13, 2008, 11:01 AM
ustcc evo's Avatar
What you experienced is likely 'stiction' caused by the parts not moving freely. In a shock you want the oil passing through the valves to do all the 'work', but when the shocks are new it takes a few miles for all the moving parts to slide easily against each other. With some shocks the stiction never goes away at great detriment to the ride and handling.
Old Jun 13, 2008, 01:31 PM
robi's Avatar
The "Robispec Race" version is hand built at KW's race shop in Germany they all are dyno run but the tolerances are much closer than "assembly line suspensions"
Old Jul 12, 2008, 11:54 PM
stockEvoIX's Avatar
Talking clockwise is stiffer
Does this mean that from the top of the strut/car, clockwise means the same direction for both compression and rebound? Meaning, if looking from the bottom, it would be counter-clockwise to increase compression? Thanks!
Old Apr 1, 2009, 01:44 PM
markg1018's Avatar
when adjusting the bump on the V3....do you need to take off the load of the suspension...like raising the car with a jack?
adjusting the rebound and bump:
clockwise = hard/close
counterclockwise = soft/open
is this correct?
Old Apr 1, 2009, 02:05 PM
robi's Avatar
no and yes
Old Apr 1, 2009, 06:33 PM
markg1018's Avatar
Robi,
whats the difference between the regular V3 than the robi specs street.
Can you make the regular V3 into one?
guyver858
Dec 31, 2016 04:22 PM
Tmosser
Dec 21, 2016 12:23 AM
Mike01gsr
Oct 13, 2007 09:59 AM
EVO8LTW
Apr 17, 2007 06:07 PM
nick735
11
Apr 15, 2007 12:58 PM
Quick Reply: How to adjust KW Coilovers
