Should shocks be replaced in pairs?
Old Jan 6, 2007, 08:06 PM
prostcj's Avatar
Tried searching but couldn't find an answer. I have a blown rear shock, should I replace both sides or will I be ok just replacing the one side?
Old Jan 6, 2007, 08:13 PM
Smike's Avatar
Personally, Id do both.
Old Jan 6, 2007, 08:29 PM
GREDDY's Avatar
Do both.
Old Jan 6, 2007, 08:31 PM
prostcj's Avatar
I'm leaning that way but I've only bought one so far. The thing is, I don't want to buy two shocks every time one goes out.
Old Jan 6, 2007, 08:42 PM
ray3328's Avatar
If you have alot of hard miles on the shocks might as well do both, it will save you money and time in the long run. But if you don't have hard miles on them and you just had the luck of having a bad shock you can get away with only changing the one.
Old Jan 6, 2007, 09:06 PM
Noob4life's Avatar
There isn't any hard and fast rule that says that you should replace shocks in pairs. Then again, shocks aren't supposed to blow/leak. General rule of thumb is you want the car properly damped at all 4 corners. If the other shocks are in danger of blowing, replace them. If not, leave them (unless you like throwing away money).
It would be a good idea on your part to determine why one of your shocks blew, though (and not the others). Or else you run the risk of paying for more new shocks to replace more blown shocks because you never solved the cause of the problem.
Old Jan 7, 2007, 05:30 AM
prostcj's Avatar
I think my problem was that I over tightened it. I was trying to tightening it full hard at autox and I twisted right through the stop. Something must of stripped internally.
My coilovers are Ksports which seem to have a reputation for blowing.
Old Jan 7, 2007, 08:52 AM
donour's Avatar
I think you solution here is simply to call the manufacturer and ask. Are you sure they need to be replaced at all rather than simply rebuilt?
d
Old Jan 7, 2007, 08:54 AM
AndyBandy's Avatar
since they are coilovers, you might as well do both. shipping for just one will probably run you 50 so just save the 50 and build both the first time.
i had my HKS rebuilt (both fronts) for around 350 which included shipping
Old Jan 7, 2007, 10:13 AM
prostcj's Avatar
The shocks are only 120 shipped. They would rebuild for that price but I didn't want to wait for the coilovers to be shipped back to me. A shop should be able to put the spring back on for 50 dollars or less.
JacobDubU
Apr 27, 2017 01:31 PM
Jabl3s
18
Jul 16, 2010 10:45 AM
AfireINSIDE
Jun 22, 2007 07:30 AM
pirate4x4lance
Aug 5, 2006 08:06 PM
speedyst9
Jul 12, 2002 12:40 AM
Quick Reply: Should shocks be replaced in pairs?
