NEW HKS EVC wiring troubleshoot help.
Old Dec 10, 2006, 02:54 AM
Clockwise's Avatar
Hi Fellas,
Just recieved my new HKS EVC.
www.hksusa.com/new-evc
Ok, the wiring harness came unlable and im having abit of problem trying to work out which is which.
Here is the wiring stated on the wiring diagram booklet.
B - 12volt ignition
U - 12 volt battery
E - ECU Ground
P - Pressure / Airflow Signal
I - RPM Signal
S - Speed Sensor
T - Throttle Position Sensor
# - Injector Signal.
OK, i only have 6 wiring according to the harness, that came with the HKS EVC.
Red
Black
White/Silver
Blue/Silver
White
Blue
Can someone out there PLEASE shed some details as to what wire is what?
Thanks in advance.
Cheers
Old Dec 10, 2006, 08:47 PM
Mitchubishievo's Avatar
Bump since I'm gonna have this EBC too...
Old Dec 15, 2006, 01:46 PM
TURBODAWG's Avatar
Did you guys get them working? How do you like them?
Old Dec 18, 2006, 01:50 AM
Clockwise's Avatar
Yup, i got mine install by pro as the instructions were all writtern in japanese and tech the installer is jap.
awesome unit, very user friendly and so much easier to tuned than my previous apexi avcr.
very stable boost to redline now as the stock unit was dropping to 16psi at top end.
turbo is now spooling and kicking in earlier, very impress
Old Dec 18, 2006, 05:49 AM
I'll be PMing you next spring if I have issues .
Old Dec 18, 2006, 09:40 AM
rogue's Avatar
Not infront of my car but I think.
Red - Switched 12V Power
Black - Ground
White - 12V Power
if anything call HKS. They will give you the info over the phone.
Daimon
Old Dec 23, 2006, 09:56 PM
fromWRXtoEVO's Avatar
Black - Ground
White - 12V Power
Daimon
No Daimon,
The HKS EVC only gets power from the accesorie source, it comes with a red wire and an attached fuse in-line and a ground.
The only white wire on the harness goes to the engine RPM signal line or speed signal line as per intruction manual page 22 para 3.2 step 5)
I installed mine last nine and have the intruction manual in front of me. Maybe I overlooked something but I might be wrong.
Carlos
Old Dec 23, 2006, 09:57 PM
Mine boost controller came with english and Japanese instructions.
Carlos
Old Dec 23, 2006, 10:05 PM
Hi Fellas,
B - 12volt ignition
U - 12 volt battery
E - ECU Ground
I - RPM Signal
S - Speed Sensor
Red
Black
White/Silver
Blue/Silver
White
Blue
Thanks in advance.
Cheers
It is very simple. I had mine installed yesterday by myself. The actual controller/display comes with 3 tiny connectors in the back, you only need to use the 2pin and 3 pin connectors.
One of the connectors in the back has the scrmable wires(you don't need to use them) The other connector has a "Y" harness . One end provides the power and ground and the other side directly connects with the harness coming straight from the EVC steping motor.
The "blue and white" wires that you are talking about are the Throtle input signal(Blue) and the Speed/rpm signal (white)
The harness coming from the EVC steping motor is white on the end that connects the display and is black on the end that connects the Steping motor.
I am writing a huge installation write up. I took more than 30 pictures, I have been just lazy to post them but please feel free to PM me if you have any questions.
This is the third EBC I have use on my cars and I consider the installation easy. Even a cave man can do it. . Seriously, PM if you get stuck but I should be opening a post tomorrow with pictures and details.
Carlos
Old Dec 23, 2006, 10:41 PM
NocturnalEVO's Avatar
im looking forward to your post about how to install the EVC 6.
I just did mines today, but not sure if I did it right lol..
btw, i dont have a tune or anything, stock ecu. What should I set the boost at?
Old Dec 23, 2006, 10:47 PM
A couple of important initial suggestions though:
1) do not use any lubricant to slide the hoses into the step motor nipples or the two vacuum filters (filter are foam filled and step motor can malfuntion and missread boost vacuum signal, it is that sensitive...)
2) be very aware that the supplied 6mm hose internal diameter is indeed too big for the stock compressor and waste gate nipples. This might give you a catastrophic visual perception that the hose is secure. I suggest you use a more appropiate better suited hose that fits the nipples tight and not loose.
Specially you that don't have a tune, pay a lot of attention to the turbo and waste gate hoses, from own experiences (13 turbo cars, 3 EBC,10 plus MBC, 2 blown 4G63'S, a few blown turbos) you can dynamite your engine or pick up some turbo wheels from the tarmac if your boost hoses are loose. I am not kidding
Carlos
Old Dec 23, 2006, 11:41 PM
i hear ya, we got a reducer and used a smaller hose to connect to the compress housing and wastegate nipples.
btw, should I set the boost at 19.5psi or so on my boost controller?
Old Dec 24, 2006, 09:19 AM
19.5psi is perfectly fine. The EBC would probably maintain that number all across the rpms range.
This is a understatement from the instruction manual (page 2), quote:
Warning Function- "If the boost exceed the user selectable warning value, the EVC notifies the user with and audiable beep and a visable warning display. Simultaneously,it lowers the boost to the baseline boost value or by a user preset value. This function prevents damage to the engine and/or the turbine due to over-boost"
HAHAHA, it is only true as long as the hoses are properly connected otherwise it would do the exact opposite, your audio signal would be your turbo exploiting, your visual signal would be pieces of the turbo in the tarmac, and unlike the manual says, you will produce engine damage.
If power fails then yes, the internal steping motor would get stuck on the existing boost value but if a hose comes loose there is not a damn thing you can do to prevent catastrophic damage.
In other words, it should work fine but a faulty installation would or could destroy your engine.
Carlos
Old Dec 24, 2006, 09:57 AM
lol you got me very scared haha... i'm thinking of switching to all metal hosing, and weld it all together lol..
Old Dec 24, 2006, 12:30 PM
Okay so I fixed the problem I was having, no CEL
Car seems to be running great right now!
Another question I have, is there way to set the A/B levels in PSI instead of the 0%-199% way they have?
Quick Reply: NEW HKS EVC wiring troubleshoot help.
