Oil Pressure Sensor Location?
Old Sep 8, 2006, 06:28 AM
GIsnickers's Avatar
Having a small problem Oil Pressure Warning Light coming on and going off, I wanted to check the pressure/sensor first. Is this sensor the same thing as the Oil Sending Unit? I can't find a parts list of a detailed Part Schematic Page for this car.
I'm going to start by doing an oil pressure test and then swapping the sensor if all seems well with the pressure.
Anyone have a schematic of where the sensor is located in the car's engine bay?
A picture would be great too if possible.
Thanks,
Old Sep 8, 2006, 06:38 AM
matt55's Avatar
Thanks,
Its on the back of the block under the TB/intake mani
look at 12-4 and 12-5 in the srevice manual , it show a good pic of it .
At idle it needs to be 4.2 psi or more and at 3500rpm you should have more than 100psi of oil presure
Old Sep 8, 2006, 06:46 AM
GIsnickers's Avatar
Easy to Reach?
Old Sep 8, 2006, 06:50 AM
matt55's Avatar
its not to bad , def need to take off the strut tower brace
Old Sep 11, 2006, 01:46 AM
ZyBeR's Avatar
Put your hand on the block on the lh side and you can feel it
Old Aug 18, 2008, 07:09 PM
EatSleepBoost's Avatar
BUMPP
sry for bumping such an old thread. however i am having the oil light flicker issue that i have read numerous posts about.
Can i get to the sensor from the top or should i just take off the LICP and whatever else in order to get to it?
does anybody have any pics or HOW TO on the oil pressure sensor replacement?
THANKS
Old Aug 19, 2008, 07:51 PM
bump
Old Aug 19, 2008, 07:59 PM
justboosted02's Avatar
from the top
take out your battery and ucip
Old Aug 19, 2008, 08:20 PM
cpoevo's Avatar
Here it is straight out of the manual. This is viewing the engine from the backside.
Old Aug 19, 2008, 11:22 PM
Spish's Avatar
Can you splice an aftermarket Oil press gauge to that spot?
Old Aug 22, 2008, 08:48 AM
cpoevo's Avatar
You should be able to install a "T" fitting on there with another sensor.
Old Jun 6, 2009, 01:50 AM
Johnboy1065's Avatar
just wondering but will an oil light effect how the ECU operates at all? as in put it in limp mode or anything?
Old Jun 6, 2009, 06:26 AM
barneyb's Avatar
This is without looking at the wiring diagram but as I recall the oil pressure switch is only connected to the gauge. In other words, the ECU wants perfect tail pipe emissions but no oil pressure is okay.
Jason Price
Jun 1, 2016 08:06 PM
JDMevoBOOST
Nov 1, 2015 03:44 AM
evotuner04
Dec 3, 2014 05:14 PM
AWDralliart09
Apr 5, 2012 09:02 AM
Bexa20
Mar 25, 2005 10:55 PM
Quick Reply: Oil Pressure Sensor Location?
