Octane math formula anyone.
Old Apr 8, 2003, 11:30 AM
BLKEVO8's Avatar
Ok here in Washington we have 92 octane at the pump, I have a 76 station 30miles away that sells 100 octane unleaded race fuel. Expensive stuff but my thought was to boost my octane to about 95-96 octane for a nice boost in HP with the stock setup. The EVO has a 14 gallon tank what would the math formula to obtain 96 octane mixing 92 with 100 octane. Anyone know the basic formula for this equation math is not my strong suite.
Old Apr 8, 2003, 12:54 PM
nine4surfah's Avatar
I forgot who posted it but a memeber from this forum posted an equation. Try searching for it under "toulene....octane....."
-randy
Old Apr 8, 2003, 01:19 PM
BLKEVO8's Avatar
OK did a little digging its pretty simple... "An alternative path to octane euphoria is to blend gasolines of different octane levels yourself. It's easier than you may think, safe, and the results are predictable. The formula for mixing gasolines of the same type is pretty straightforward. When you mix a 50/50 blend of two unleaded fuels, simply average the two octane ratings to determine what's in the tank If you mix 94 and 100, you get 97. The same generally holds true for leaded gasolines, assuming the lead content is nearly equal."
Old Apr 8, 2003, 01:32 PM
El Jefe
WestSideBilly's Avatar
Rather than drive 30 miles all the time, why not buy a 55 gallon barrel of 100 octane gas (probably $150-175), and mix your own stuff at home?
Old Apr 8, 2003, 01:40 PM
BLKEVO8's Avatar
Well that woulds be cool but unfortunatley its $6.20 a gallon! ( I just called) and I dont have a truck or anything to haul a 55 gal. drum unless I rent something, plus they pump it out a really big drum so expensive anyway you dice it. I was thinking of buying a couple metal 5gal. and fill them up and do a 6gal. to 5 gal. mix, plus fill up when I am there that should limit the trip to once a month.
Old Apr 13, 2003, 09:33 AM
Sunder's Avatar
Do you guys retune your engines or run higher boost to take advantage of the higher octane?
Last time I checked, running higher octane by itself gave no benefit, except to make the fuel harder to auto-ignite.
Old Apr 13, 2003, 09:44 AM
on3ofak1nd's Avatar
Yes this is true, in my young years i worked at a gas station and most if not all do not even have seperate tanks for mid grades. If a stations lowest octane is 87 and highest is 97 then they will have a 87 tank and a 97, if you select 89 the pump will simply combine the two at the correct ratio to achieve the mid grade. So it would not be hard to do yourself. Unfortunately the station owner where i worked was rather unorganized and we would frequently run out of 87, which would effectivly put us out of all mid grades, in turn a lot of customers just pumped premium just because they were too lazy to go some place else. Funny watching a Geo tracker fill up with premium.
EDIT: while on the subject, the myth that all gas is the same is not true, getting gas from a Texaco for instance would provide a much cleaner fuel than that from a no name station which generally runs a generic fuel. Of course its all additives, but non the less its at least best to always run the same "brand" gasoline in my opinion.
Old Apr 13, 2003, 01:36 PM
leousm's Avatar
Lightbulb
Ok, a simple formula that I use is as follows:
( octane * gallons ) + (octane * gallons)
total amount of gallons
for example,
Let's say that you want to mix 5 gallons of 93 octane with 2 gallons of 117 octane race fuel (such as VP C16).
(93*5) + (117*2)
699/7 = 99.86 octane
Remember that this is approximate and assumes that both octanes are meassured the same way (ex. (R+M)/2 ), but you get the idea.
Old Apr 14, 2003, 05:39 PM
netmand's Avatar
Fuel Mixing Octane Calculator
Last edited by netmand; Apr 6, 2006 at 12:29 PM. Reason: URL updated to a valid one
Old Apr 14, 2003, 05:44 PM
BLKEVO8's Avatar
Wow that is one great site thanks, forums are a true collective think tank
Old Apr 15, 2003, 08:52 AM
ShapeGSX's Avatar
You will have a tough time figuring out how much fuel you have in your tank. The fuel level gauge is quite deceptive.
What I do is drain out all the pump gas that is in my tank before putting in a few gallons of race gas. There is more to race gas than just octane. I'd much rather just run the pure stuff when it counts.
You can drain your fuel tank by removing the fuel return line from the end of the fuel injector rail. Then hook up a 6 foot piece of fuel line to the fuel pressure regulator. Run the other end of the line into a gas can. Then either turn on the fuel pump (I installed a switch to do so) or just run the car until it starts sputtering.
Old Apr 24, 2003, 06:00 PM
jfh
jfh's Avatar
Great link. Thanks.
Old May 1, 2003, 08:57 AM
rallyman5's Avatar
very cool, thanks!
DaGermanEvo9
26
Apr 5, 2011 09:08 PM
evane
E85 / Ethanol
Dec 4, 2008 09:06 AM
Dem_z
Lancer Aftermarket Forced Induction Tech
26
Jan 17, 2007 02:01 PM
Tarmac8
Mar 16, 2006 10:29 PM
Miss Evo 8
Jun 15, 2004 05:12 PM
Quick Reply: Octane math formula anyone.
